Storage Pools window
Contributors netapp-ivanad
You can use the Storage Pools window to create, display, and manage a dedicated cache of SSDs, also known as storage pools. These storage pools can be associated with a non-root aggregate to provide SSD cache and with a Flash Pool aggregate to increase its size.
This page is not available for a cluster containing nodes with All Flash Optimized personality.
Command buttons
  • Create
    Opens the Create Storage Pool dialog box, which enables you to create a storage pool.
  • Add Disks
    Opens the Add Disks dialog box, which enables you to add cache disks to a storage pool.
  • Delete
    Deletes the selected storage pool.
  • Refresh
    Updates the information in the window.
Storage pools list
  • Name
    Displays the name of the storage pool.
  • Total Cache
    Displays the total cache size of the storage pool.
  • Spare Cache
    Displays the available spare cache size of the storage pool.
  • Used Cache (%)
    Displays the percentage of used cache size of the storage pool.
  • Allocation Unit
    Displays the minimum allocation unit of the total cache size that you can use to increase the size of your storage pool.
  • Owner
    Displays the name of the HA pair or the node with which the storage pool is associated.
  • State
    Displays the state of the storage pool, which can be Normal, Degraded, Creating, Deleting, Reassigning, or Growing.
  • Is Healthy
    Displays whether storage pool is healthy or not.
Details tab
Displays detailed information about the selected storage pool, such as the name, health, storage type, disk count, total cache, spare cache, used cache size (in percent), and allocation unit. The tab also displays the names of the aggregates that are provisioned by the storage pool.
Disks tab
Displays detailed information about the disks in the selected storage pool, such as the names, disk types, useable size, and total size.
Related information
