Users window
Contributors netapp-ivanad
You can use the Users window to manage user accounts, to reset the password of a user, and to view information about all of the user accounts.
Command buttons
  • Add
    Opens the Add User dialog box, which enables you to add user accounts.
  • Edit
    Opens the Modify User dialog box, which enables you to modify user login methods.
    Note
    It is a best practice to use a single role for all of the access and authentication methods of a user account.
  • Delete
    Enables you to delete a selected user account.
  • Change Password
    Opens the Change Password dialog box, which enables you to reset a selected user’s password.
  • Lock
    Locks the user account.
  • Refresh
    Updates the information in the window.
Users list
The area below the users list displays detailed information about the selected user.
  • User
    Displays the name of the user account.
  • Account Locked
    Displays whether the user account is locked.
User Login Methods area
  • Application
    Displays the access method that a user can use to access the storage system. The supported access methods include the following:
    • System console (console)
    • HTTP(S) (http)
    • ONTAP API (ontapi)
    • Service Processor (service-processor)
    • SSH (ssh)
  • Authentication
    Displays the default supported authentication method, which is “password”.
  • Role
    Displays the role of a selected user.
