Add NIS domains
Contributors NetAppZacharyWambold netapp-ivanad
You can maintain host information centrally by using NIS. You can use System Manager to add the NIS domain name of your storage system. Only one NIS domain can be active on a storage virtual machine (SVM) at any given time.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Services pane, click NIS.
  4. Click Create.
  5. Type the NIS domain name, and then add one or more NIS servers.
  6. Click Create.
