Assigning array LUNs
Contributors netapp-ivanad
You can use System Manager to assign unassigned array LUNs to an existing aggregate to increase the size of the aggregate.
About this task
  • You can assign array LUNs if the following conditions are true:
    • The container type of the selected array LUNs must be “unassigned”.
    • The disks must be connected to nodes in an HA pair.
    • The disks must be visible to the node.
  • For MetroCluster configurations, you cannot use System Manager to assign array LUNs as spares.
    You must use the command-line interface instead.
Steps
  1. Click Storage > Aggregates & Disks > Array LUNs.
  2. Select the array LUNs, and then click Assign.
  3. In the Assign Array LUNs dialog box, select the node to which you want to assign the array LUNs.
  4. Click Assign.
