Changing an FC or FCoE node name
Contributors netapp-ivanad
If you replace a storage system chassis and reuse it in the same Fibre Channel SAN, the node name of the replaced storage system might be duplicated in certain cases. You can change the node name of the storage system by using System Manager.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Protocols pane, click FC/FCoE.
  4. Click Edit.
  5. Type the new name, and then click OK.
Related information
