Create quotas
Contributors NetAppZacharyWambold netapp-ivanad
Quotas enable you to restrict or track the disk space and number of files that are used by a user, group, or qtree. You can use the Add Quota wizard in System Manager to create a quota and to apply the quota to a specific volume or qtree.
About this task
Using System Manager, the minimum value that you can specify for the hard limit and soft limit on the number of files that the quota can own is 1000. If you want to specify a value lower than 1000, you should use the command-line interface (CLI).
Steps
  1. Click Storage > Quotas.
  2. From the drop-down menu in the SVM field, select the storage virtual machine (SVM) on which you want to create a quota.
  3. In the User Defined Quotas tab, click Create.
    The Create Quota Wizard is displayed.
  4. Type or select information as prompted by the wizard.
  5. Confirm the details, and then click Finish to complete the wizard.
What to do next
You can use the local user name or RID to create user quotas. If you create the user quota or group quota by using the user name or group name, then the /etc/passwdfile and the/etc/groupfile must be updated, respectively.
Related information
