Create schedules
Contributors NetAppZacharyWambold netapp-ivanad
You can create schedules to run a job at a specific time or at regular periods by using System Manager.
About this task
When you create a schedule in a MetroCluster configuration, it is a best practice to create an equivalent schedule on the cluster in the surviving site as well.
Steps
  1. Click Protection > Schedules.
  2. Click Create.
  3. In the Create Schedule dialog box, specify the schedule name.
  4. Create a schedule based on your requirements:
    If you want to create…​ Do this…​
    A daily or a specific schedule on certain days
    Select Basic, and specify the schedule and recurrence details (in hours and minutes).
    A schedule that runs at a specific interval
    Select Interval, and specify the schedule and recurrence details (in days, hours, and minutes).
    A schedule that runs at a specific period
    Select Advanced, and specify the schedule and recurrence details (in months, days, weekdays, hours, and minutes).
  5. Click Create.
