Create VLAN interfaces
Contributors NetAppZacharyWambold netapp-ivanad
You can create a VLAN to maintain separate broadcast domains within the same network domain by using System Manager.
Steps
  1. Click Network > Ethernet Ports.
  2. Click Create VLAN.
  3. In the Create VLAN dialog box, select the node, the physical interface, and the broadcast domain (if required).
    The physical interface list includes only Ethernet ports and interface groups. The list does not display interfaces that are in another interface group or an existing VLAN.
  4. Type a VLAN tag, and then click Add.
    You must add unique VLAN tags.
  5. Click Create.
Related information
