Deleting efficiency policies
Contributors netapp-ivanad
You can use System Managerto delete an efficiency policy that is no longer required.
Before you begin
The efficiency policy must be disabled.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Policies pane, click Efficiency Policies.
  4. Select the efficiency policy that you want to delete, and then click Delete.
  5. Select the confirmation check box, and then click Delete.
