Deleting licenses
Contributors netapp-ivanad
You can use the Licenses window in System Manager to delete any software license that is installed on a cluster or a node.
Before you begin
The software license that you want to delete must not be used by any service or feature.
Steps
  1. Click Configuration > Cluster > Licenses.
  2. In the Licenses window, perform the appropriate action:
    If you want to…​ Do this…​
    Delete a specific license package on a node or a master license
    Click the Details tab.
    Delete a specific license package across all of the nodes in the cluster
    Click the Packages tab.
  3. Select the software license package that you want to delete, and then click Delete.
    You can delete only one license package at a time.
  4. Select the confirmation check box, and then click Delete.
Results
The software license is deleted from your storage system. The deleted license is also removed from the list of licenses in the Licenses window.
Related information
