Deleting mirror relationships
Contributors netapp-ivanad
You can delete a mirror relationship and permanently end the mirror relationship between the source and destination volumes. When a mirror relationship is deleted, the base Snapshot copy on the source volume is deleted.
About this task
It is a best practice to break the mirror relationship before deleting the relationship.
Steps
  1. Click Protection > Volume Relationships.
  2. Select the mirror relationship that you want to delete and click Delete.
  3. Select the confirmation check boxes to delete the mirror relationship and to release the base Snapshot copies, and then click Delete.
Results
The relationship is deleted, and the base Snapshot copy on the source volume is deleted.
Related information
