Deleting an NVMe subsystem
Contributors netapp-ivanad
You can use System Manager to delete an NVMe subsystem from a cluster.
About this task
The following actions occur when you delete an NVMe subsystem:
  • If the NVMe subsystem has configured hosts, then mapped hosts will be removed.
  • If the NVMe subsystem has mapped namespaces, then they will be unmapped.
Steps
  1. Find the NVMe subsystem you want to delete on the NVMe Subsystem window.
  2. Check the box to the left of the name of the subsystem you want to delete.
  3. Click Delete.
    A Warning message is displayed.
  4. Click the Delete the NVMe Subsystem check box to confirm the deletion, then click Yes.
    The NVMe subsystem is deleted from the cluster, and the NVMe Subsystems window is displayed.
Related information
