Deleting qtrees
Contributors netapp-ivanad
You can delete a qtree and reclaim the disk space that the qtree uses within a volume by using System Manager. When you delete a qtree, all of the quotas that are applicable to that qtree are no longer applied by ONTAP.
Before you begin
  • The qtree status must be normal.
  • The qtree must not contain any LUN.
Steps
  1. Click Storage > Qtrees.
  2. In the Qtrees window, select one or more qtrees that you want to delete, and then click Delete.
  3. Select the confirmation check box, and then click Delete.
  4. Verify that the qtree that you deleted is no longer included in the list of qtrees in the Qtrees window.
Related information
