Deleting quotas
Contributors netapp-ivanad
You can use System Manager to delete one or more quotas when your users and their storage requirements and limitations change.
Steps
  1. Click Storage > Quotas.
  2. From the drop-down menu in the SVM field, select the storage virtual machine (SVM) on which the quotas that you want to delete reside.
  3. Select one or more quotas that you want to delete, and then click Delete.
  4. Select the confirmation check box, and then click Delete.
Related information
