Deleting storage pools
Contributors netapp-ivanad
You might want to delete a storage pool when the cache of the storage pool is not optimal or when it is no longer used by any aggregate or Flash Pool aggregate. You can delete a storage pool by using the Delete Storage Pool dialog box in System Manager.
Before you begin
The storage pool must not be used by any aggregate.
Steps
  1. Click Storage > Aggregates & Disks > Storage Pools.
  2. In the Storage Pools window, select the storage pool that you want to delete, and then click Delete.
  3. In the Delete Storage Pool dialog box, click Delete.
Related information
