Deleting VLANs
Contributors netapp-ivanad
You can delete VLANs that are configured on network ports by using System Manager. You might have to delete a VLAN before removing a NIC from its slot. When you delete a VLAN, the VLAN is automatically removed from all of the failover rules and groups that use the VLAN.
Before you begin
No LIFs must be associated with the VLAN.
Steps
  1. Click Network > Ethernet Ports.
  2. Select the VLAN that you want to delete, and then click Delete.
  3. Select the confirmation check box, and then click Delete.
Related information
