Editing broadcast domain settings
Contributors netapp-ivanad
You can use System Manager to modify the attributes of a broadcast domain such as the name, the MTU size, and the ports that are associated with the broadcast domain.
About this task
  • You must not modify the MTU size of the broadcast domain to which the management port e0M is assigned.
  • You cannot use System Manager to edit broadcast domains in the cluster IPspace.
    You must use the command-line interface (CLI) instead.
Steps
  1. Click Network > Broadcast Domains.
  2. Select the broadcast domain that you want to modify, and then click Edit.
  3. In the Edit Broadcast Domain dialog box, modify the broadcast domain attributes as required.
  4. Click Save and Close.
Related information
