Editing Ethernet port settings
Contributors netapp-ivanad
You can edit Ethernet port settings such as the duplex mode and speed settings by using System Manager.
Steps
  1. Click Network > Ethernet Ports.
  2. Select the physical port, and then click Edit.
  3. In the Edit Ethernet Port dialog box, modify the duplex mode and speed settings to either manual or automatic.
  4. Click Edit.
