Editing interface group settings
Contributors netapp-ivanad
You can use System Manager to add ports to an interface group, to remove ports from an interface group, and to modify the usage mode and load distribution pattern of the ports in an interface group.
About this task
You cannot modify the MTU settings of an interface group that is assigned to a broadcast domain.
Steps
  1. Click Network > Ethernet Ports.
  2. Select an interface group, and then click Edit.
  3. Modify the interface group settings as required, and then click Save and Close.
Related information
