Editing IPspaces
Contributors netapp-ivanad
You can use System Manager to rename an existing IPspace.
About this task
  • All IPspace names must be unique within a cluster and must not consist of names that are reserved by the system, such as local or localhost.
  • The system-defined “Default” IPspace and “Cluster” IPspace cannot be modified.
Steps
  1. Click Network > IPspaces.
  2. Select the IPspace that you want to modify, and then click Edit.
  3. In the Edit IPspace dialog box, specify a new name for the IPspace.
  4. Click Rename.
