Editing network interface settings
Contributors netapp-ivanad
You can use System Manager to modify the network interface to enable management access for a data LIF.
About this task
  • You cannot modify the network settings of cluster LIFs, cluster management LIFs, or node management LIFs through System Manager.
  • You cannot enable management access for an intercluster LIF.
Steps
  1. Click Network > Network Interfaces.
  2. Select the interface that you want to modify, and then click Edit.
  3. In the Edit Network Interface dialog box, modify the network interface settings as required.
  4. Click Save and Close.
Related information
