Editing NFS settings
Contributors netapp-ivanad
You can use System Manager to edit the NFS settings such as enabling or disabling NFSv3, NFSv4, and NFSv4.1, enabling or disabling read and write delegations for NFSv4 clients, and enabling NFSv4 ACLs. You can also edit the default Windows user.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Protocols pane, click NFS.
  4. In the NFS window, click Edit.
  5. In the Edit NFS Settings dialog box, make the required changes.
  6. Click Save and Close.
Related information
