Editing qtrees
Contributors netapp-ivanad
You can use System Manager to modify the properties of a qtree such as the security style, enable or disable opportunistic locks (oplocks), and assign a new or existing export policy.
Steps
  1. Click Storage > Qtrees.
  2. Select the qtree that you want to edit, and then click Edit.
  3. In the Edit Qtree dialog box, edit the following properties as required:
    • Oplocks
    • Security style
    • Export policy
  4. Click Save.
  5. Verify the changes that you made to the selected qtree in the Qtrees window.
Related information
