Editing quota limits
Contributors netapp-ivanad
You can use System Manager to edit the disk space threshold, the hard limit and soft limit on the amount of disk space that the quota target can use, and the hard limit and soft limit on the number of files that the quota target can own.
Steps
  1. Click Storage > Quotas.
  2. From the drop-down menu in the SVM field, select the storage virtual machine (SVM) on which the quota that you want to edit resides.
  3. Select the quota that you want to edit, and click Edit Limits.
  4. In the Edit Limits dialog box, edit the quota settings as required.
    One hundred (100) is the minimum value that you can specify for the hard limit and soft limit on the number of files that the quota can own. If you want to specify a value lower than 100, you should use the command-line interface (CLI).
  5. Click Save and Close.
  6. Verify the changes that you made to the selected quota in the User Defined Quotas tab.
Related information
