Editing roles
Contributors netapp-ivanad
You can use System Manager to modify an access-control role’s access to a command or command directory and to restrict a user’s access to only a specified set of commands. You can also remove a role’s access to the default command directory.
Steps
  1. Click nas bridge 202 icon settings olh 96 97.
  2. In the Management pane, click Roles.
  3. In the Roles window, select the role that you want to modify, and then click Edit.
  4. In the Edit Role dialog box, modify the role attributes, and then click Modify.
  5. Verify the changes that you made in the Roles window.
