Editing roles
Contributors netapp-ivanad
You can use System Manager to modify the access of an access-control roleto a command or command directory and to restrict a user’s access to only a specified set of commands.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the SVM User Details pane, click Roles.
  4. Select the role that you want to modify, and then click Edit.
  5. Modify the role attributes, and then click Modify.
