Editing SVM relationships
Contributors netapp-ivanad
You can use System Manager to modify the properties of an SVM relationship.
Steps
  1. Click Protection > SVM Relationship.
  2. Select the SVM relationship that you want to modify, and then click Edit.
  3. Select the SVM relationship type.
    If the SVM relationships were created before ONTAP 9.3, then changing the SVM relationship type from mirror to mirror and vault is not allowed.
  4. Modify the protection policy, the protection schedule, and the option to copy the source SVM configuration, as required.
  5. Click Save to save the changes.
