Enabling or disabling AutoSupport settings
Contributors netapp-ivanad
You can enable or disable AutoSupport settings on your storage system by using System Manager. AutoSupport messages enable you to monitor your storage system health or send notifications to technical support and your internal support organization.
About this task
The AutoSupport option is enabled by default.
Steps
  1. Click nas bridge 202 icon settings olh 96 97 > AutoSupport.
  2. Select the node, and then click Enable or Disable.
  3. Click OK.
  4. Verify that the AutoSupport status correctly displays the change you made.
