Enabling or disabling a CIFS group policy configuration
Contributors netapp-ivanad
You can enable or disable the CIFS group policy configuration from the CIFS window in System Manager.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. Click the Domain tab.
  4. In the Group Policy area, select the group policy configuration that you want to enable or disable, and then click Enable or Disable, as required.
