Enabling or disabling DDNS
Contributors netapp-ivanad
You can use System Manager to enable or disable DDNS on a storage system.
About this task
  • DNS is enabled by default.
  • DDNS is disabled by default.
  • System Manager does not perform any validation checks for the DNS and DDNS settings.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Services pane, click DNS/DDNS.
  4. In the DNS/DDNS Services window, click Edit.
  5. In the Edit DNS/DDNS Settings dialog box, enable DDNS by selecting the DDNS service check box.
    You can disable DDNS by clearing the DDNS service check box.
  6. Click OK.
Related information
