Enabling or disabling Flash Cache modules
Contributors netapp-ivanad
You can enable or disable the external cache functionality for a storage system that has a Flash Cache module installed by using System Manager. You can enable Flash Cache modules based on the workload requirements of your storage system.
Steps
  1. Click Configuration > Hardware Cache
  2. If you want to modify a module or modules, move the slider button to enable or disable each module, as required.
