Enabling or disabling SNMP
Contributors netapp-ivanad
You can enable or disable SNMP on your clusters by using System Manager. SNMP enables you to monitor the storage virtual machines (SVMs) in a cluster to avoid issues before they can occur and to prevent issues from occurring.
Steps
  1. Click nas bridge 202 icon settings olh 96 97.
  2. In the Setup pane, click SNMP.
  3. In the SNMP window, click either Enable or Disable.
