Enabling or disabling SNMP traps
Contributors netapp-ivanad
SNMP traps enable you to monitor the health and state of the various components of your storage system. You can use the Edit SNMP Settings dialog box in System Manager to enable or disable SNMP traps on your storage system.
About this task
Although SNMP is enabled by default, SNMP traps are disabled by default.
Steps
  1. Click nas bridge 202 icon settings olh 96 97.
  2. In the Setup pane, click SNMP.
  3. In the SNMP window, click Edit.
  4. In the Edit SNMP Settings dialog box, select the Trap hosts tab, and then select or clear the Enable traps check box to enable or disable SNMP traps, respectively.
  5. If you enable SNMP traps, add the host name or IP address of the hosts to which the traps are sent.
  6. Click OK.
Related information
