Initializing the ComplianceClock time
Contributors netapp-ivanad
You can use System Manager to initialize the ComplianceClock time to the current cluster time. You must initialize the ComplianceClock time in order to create SnapLock aggregates.
Before you begin
The SnapLock license must be installed.
About this task
You cannot modify or stop the ComplianceClock time after it is initialized.
Steps
  1. Click Storage > Nodes.
  2. Select the node, and then click Initialize ComplianceClock.
  3. In the Initialize ComplianceClock dialog box, click Yes to initialize the ComplianceClock time to the current cluster time.
