Modifying LIFs that are configured for the remote cluster
Contributors netapp-ivanad
You can use System Manager to modify the IPspace and intercluster logical interfaces (LIFs) that are configured for the remote cluster. You can add new intercluster IP addresses or remove existing IP addresses.
Before you begin
You must have at least one intercluster IP address to create the cluster peer relationship.
Steps
  1. Click Configuration > Cluster > Configuration Updates.
  2. Select the peered cluster, and click Edit
    The drop-down menu displays.
  3. Click Peer Cluster Network Parameters.
    The Edit Peer Network Parameters dialog window displays.
  4. If required, modify the following fields:
    • IPspace: Select the IPspace from the pull-down menu.
    • Intercluster LIFs: Add or remove intercluster IP addresses. You can add multiple IP addresses by separating them with commas.
  5. Click Modify.
  6. Verify the changes that you made in the Cluster Peers window.
