Quiescing a vault relationship
Contributors netapp-ivanad
You can use System Manager to disable data transfers to the destination FlexVol volume by quiescing the vault relationship.
Steps
  1. Click Protection > Volume Relationships.
  2. Select the relationship for which you want to stop the scheduled data transfers, and click Operations > Quiesce.
  3. In the Quiesce window, click Quiesce.
Results
If there is no transfer in progress, the transfer status is displayed as Quiesced. If a transfer is in progress, the transfer is not affected, and the transfer status is displayed as Quiescing until the transfer is complete.
Related information
