Renaming the MetroCluster local site (Site A)
Contributors netapp-ivanad
You can use System Manager to rename the MetroCluster local site (Site A) in a cluster.
Steps
  1. Click Configuration > Configuration Updates.
  2. Click Update cluster name.
  3. Update the name in the text box, then click Submit.
    You can view the updated name when the MetroCluster Site A status is displayed.
  4. To display the updated name of MetroCluster Site A when viewing it from the remote site (Site B), execute the following command within the CLI on the remote site (Site B): cluster peer modify-local-name
