Resuming mirror relationships
Contributors netapp-ivanad
You can resume a quiesced mirror relationship. When you resume the relationship, normal data transfer to the mirror destination is resumed and all the mirror activities are restarted.
About this task
If you have quiesced a broken mirror relationship from the command-line interface (CLI), you cannot resume the relationship from System Manager. You must use the CLI to resume the relationship.
Steps
  1. Click Protection > Volume Relationships.
  2. Select the mirror relationship that you want to resume.
  3. Click Operations > Resume.
  4. Select the confirmation check box and click Resume.
Results
Data transfer to the mirror destination resumes for the selected mirror relationship.
Related information
