PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
- System Manager Classic docs
NFS configuration
- Overview
NFS configuration workflow
Create a new NFS-enabled SVM
Configure NFS access to an existing SVM
- Add NFS access to an existing SVM
- Open the export policy of the SVM root volume(Configure NFS access to an existing SVM)
- Configure LDAP (Configure NFS access to an existing SVM )
- Verify NFS access from a UNIX administration host
- Configure and verify NFS client access (Configure NFS access to an existing SVM)
Add an NFS volume to an NFS-enabled SVM
NFS configuration for ESXi using VSC
- Overview
NFS Client Configuration for ESXi workflow
- Verify that the configuration is supported
- Complete the NFS client configuration worksheet
- Install
- Add the storage cluster to VSC
- Configure your network for best performance
Configure the ESXi host
- Create an aggregate
- Decide where to provision the new volume
- Create a new NFS-enabled SVM
- Verify that NFS is enabled on an existing SVM
- Provision a datastore and create its containing volume
- Verify NFS access from an ESXi host
- Deploy the NFS Plug-in for VMware VAAI
- Mount datastores on hosts
SMB/CIFS and NFS multiprotocol configuration
- Overview
Multiprotocol configuration workflow
SMB/CIFS configuration
FC configuration for ESXi using VSC
- Overview
FC configuration workflow
- Verify that the FC configuration is supported
- Complete the FC configuration worksheet
- Install Virtual Storage Console
- Add the storage cluster or SVM to VSC for VMware vSphere
- Update the HBA driver, firmware, and BIOS
- Configure the ESXi host best practice settings
Decide where to provision the volume
- Zone the FC switches by the host and LIF WWPNs
- Provision a datastore and create its containing LUN and volume
- Verify that the host can write to and read from the LUN
FC configuration for Red Hat Enterprise Linux
- Overview
FC configuration and provisioning workflow
- Install the HBA utility from the HBA vendor
- Install Linux Unified Host Utilities and optimizing I/O performance
- Record the WWPN for each host FC port
- Configure DM-Multipath
- Discover new SCSI devices (LUNs) and multipath devices
- Configure logical volumes on multipath devices and create a file system
- Verify that the host can write to and read from a multipath device
FC configuration for Windows
- Overview
- Install Windows Unified Host Utilities
- Discover new disks
- Initialize and formatting the LUN
iSCSI configuration for ESXi using VSC
- Overview
iSCSI configuration workflow
- Verify that the iSCSI configuration is supported
- Complete the iSCSI configuration worksheet
- Configure host iSCSI ports and vSwitches
- Enable the iSCSI software adapter
- Bind iSCSI ports to the iSCSI software adapter
- Test iSCSI paths from the host to the storage cluster
- Provision a datastore and creating its containing LUN and volume
iSCSI configuration for Red Hat Enterprise Linux
- Overview
iSCSI configuration and provisioning workflow
- Record the iSCSI node name
- Set the iSCSI replacement timeout value
- Start the iSCSI service
- Start the iSCSI sessions with the target
- Configure logical volumes on multipath devices and creating a file system
iSCSI configuration for Windows
- Overview
- Record the iSCSI initiator node name
- Start iSCSI sessions with the target
Cluster and SVM peering configuration
Volume disaster recovery
Volume disaster recovery preparation
Volume backup using SnapVault
Volume restore management using SnapVault
Cluster administration
Cluster management using System Manager 9.6 and 9.7
- Understand System Manager
Set up the cluster by using ONTAP System Manager
- Access a cluster by using the ONTAP System Manager browser-based graphic interface
- Configure System Manager options
- View ONTAP System Manager log files
Set up the cluster
- Set up the network
Set up physical storage
Create SVMs
- Set up SAML authentication
- Set up peering
Manage clusters
Applications
- Configuration update
- Service Processors
- Cluster peers
- High availability
- Licenses
- Cluster Expansion
Update clusters
- Date and time settings of a cluster
- SNMP
- LDAP
- Users
- Roles
- Manage the network
- IPspaces
- Broadcast domains
- Subnets
- Network interfaces
- Ethernet ports
- FC/FCoE and NVMe adapters
Storage tiers
- Edit aggregates
- Delete aggregates
- Change the RAID configuration when creating an aggregate
- Provisioning cache by adding SSDs
- Add capacity disks
- Change the RAID group when adding capacity disks
- Moving FlexVol volumes
- Mirroring aggregates
- View aggregate information
- Installing a CA certificate if you use StorageGRID
- How you can use effective ONTAP disk type for mixing HDDs
- What compatible spare disks are
- How System Manager works with hot spares
- Rules for displaying disk types and disk RPM
- Storage recommendations for creating aggregates
- Storage Tiers window
- Configure and managing cloud tiers
- Aggregates
- Storage pools
- Reassigning disks to nodes
Disks
- Array LUNs
- Nodes
- Hardware Cache
- Events
- System alerts
- AutoSupport notifications
- Jobs
- Flash Pool statistics
SVM Dashboard window
Volumes
- Edit volume properties
- Edit data protection volumes
- Delete volumes
- Create FlexClone volumes
- Create FlexClone files
- Splitting a FlexClone volume from its parent volume
- View the FlexClone volume hierarchy
- Change the status of a volume
- View the list of saved Snapshot copies
- Create Snapshot copies outside a defined schedule
- Setting the Snapshot copy reserve
- Hiding the Snapshot copy directory
- Scheduling automatic creation of Snapshot copies
- Restore a volume from a Snapshot copy
- Extend the expiry date of Snapshot copies
- Rename Snapshot copies
- Delete Snapshot copies
- Resize volumes
- Enable storage efficiency on a volume
- Change the deduplication schedule
- Run deduplication operations
- Moving FlexVol volumes between aggregates or nodes
- Assigning volumes to Storage QoS
- Create a mirror relationship from a source SVM
- Create a vault relationship from a source SVM
- Create a mirror and vault relationship from a source SVM
- Create an NFS datastore for VMware
- Change the tiering policy of a volume
- Create FlexGroup volumes
- View FlexGroup volume information
- Edit FlexGroup volumes
- Specifying advanced options for a FlexGroup volume
- Resize FlexGroup volumes
- Change the status of a FlexGroup volume
- Delete FlexGroup volumes
- Create FlexCache volumes
- View FlexCache volume information
- Edit FlexCache volumes
- Specifying advanced options for a FlexCache volume
- Resize FlexCache volumes
- Change the status of a FlexCache volume
- Delete FlexCache volumes
- How volume guarantees work for FlexVol volumes
- Using space reservations with FlexVol volumes
- Options for resizing volumes
- Volumes window
- Junction Path
- Shares
LUNs
- Create FC SAN optimized LUNs
- Application-specific LUN settings
- Create LUNs
- Delete LUNs
- Manage initiator groups
- Create portsets
- Cloning LUNs
- Edit LUNs
- Bringing LUNs online
- Take LUNs offline
- Moving LUNs
- Assigning LUNs to storage QoS
- Edit initiator groups
- Edit initiators
- View LUN information
- View initiator groups
- Guidelines for working with FlexVol volumes that contain LUNs
- Understand space reservations for LUNs
- Guidelines for using LUN multiprotocol type
- LUNs window
- Qtrees
- Quotas
CIFS protocol
- NFS protocol
Set up NVMe
- iSCSI protocol
- FC/FCoE protocol
- Export policies
- Efficiency policies
Manage QoS policy groups
- NIS services
- LDAP client services
- LDAP configuration services
- Kerberos realm services
- DNS/DDNS Services
- SVM users
- UNIX
Local windows group
- Name mapping
Mirror relationships
Vault relationships
Mirror and vault relationships
- Protection window
- SVM relationships
- Manage protection policies
- Manage Snapshot policies
- Manage schedules
- ONTAP docs
- Legal Notices
