Setting the default security for iSCSI initiators
Contributors netapp-ivanad
You can use System Manager to remove the authentication settings for an initiator and to use the default security method to authenticate the initiator.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Protocols pane, click iSCSI.
  4. In the Initiator Security tab, select the initiator for which you want to change the security setting.
  5. Click Set Default in the Initiator Security area, and then click Set Default in the confirmation dialog box.
Related information
