Unmounting FlexVol volumes
Contributors netapp-ivanad
You can use the Junction Path option of Storage pane in System Manager to unmount FlexVol volumes from a junction in the storage virtual machine (SVM) namespace.
Steps
  1. Click Storage > Junction Path.
  2. From the drop-down menu in the SVM field, select the SVM from which you want to unmount a volume.
  3. Select the volumes that have to be unmounted, and then click Unmount.
  4. Select the confirmation check box, and then click Unmount.
