Updating a vault relationship
Contributors netapp-ivanad
You can use System Manager to manually initiate an unscheduled incremental update. You might require a manual update to prevent data loss due to an upcoming power outage, scheduled maintenance, or data migration.
Before you begin
The vault relationship must be initialized.
Steps
  1. Click Protection > Volume Relationships.
  2. Select the relationship for which you want to update the data, and click Operations > Update.
  3. Choose one of the following options:
    • Select As Per Policy to perform an incremental transfer from the recent common Snapshot copy between the source and destination volumes.
    • Select Select Snapshot copy and specify the Snapshot copy that you want to transfer.
  4. Select Limit transfer bandwidth to to limit the network bandwidth that is used for transfers and specify the maximum transfer speed.
  5. Click Update.
  6. Verify the transfer status in the Details tab.
Related information
