Install and maintain
Install the RCF on Cisco Nexus 3132Q-V cluster switches
Contributors netapp-yvonneo netapp-jsnyder
Install the reference configuration file (RCF) on Cisco Nexus 3132Q-V cluster switches after initial setup. The RCF defines port assignments and network settings required for cluster operation.
Before you begin
Verify the following installations and connections:
  • A current backup of the switch configuration.
  • A fully functioning cluster (no errors in the logs or similar issues).
  • The current RCF.
  • A console connection to the switch, required when installing the RCF.
About this task
The procedure requires the use of both ONTAP commands and Cisco Nexus 3000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
No operational inter-switch link (ISL) is needed during this procedure. This is by design because RCF version changes can affect ISL connectivity temporarily. To enable non-disruptive cluster operations, the following procedure migrates all of the cluster LIFs to the operational partner switch while performing the steps on the target switch.
Step 1: Install the RCF on the switches
  1. Display the cluster ports on each node that are connected to the cluster switches:
    network device-discovery show
    Show example
    cluster1::*> network device-discovery show
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
    cluster1-01/cdp
                e0a    cs1                       Ethernet1/7       N3K-C3132Q-V
                e0d    cs2                       Ethernet1/7       N3K-C3132Q-V
    cluster1-02/cdp
                e0a    cs1                       Ethernet1/8       N3K-C3132Q-V
                e0d    cs2                       Ethernet1/8       N3K-C3132Q-V
    cluster1-03/cdp
                e0a    cs1                       Ethernet1/1/1     N3K-C3132Q-V
                e0b    cs2                       Ethernet1/1/1     N3K-C3132Q-V
    cluster1-04/cdp
                e0a    cs1                       Ethernet1/1/2     N3K-C3132Q-V
                e0b    cs2                       Ethernet1/1/2     N3K-C3132Q-V
    cluster1::*>
  2. Check the administrative and operational status of each cluster port.
    1. Verify that all the cluster ports are up with a healthy status:
      network port show -ipspace Cluster
      Show example
      cluster1::*> network port show -ipspace Cluster
      Node: cluster1-01
        Ignore
                                                        Speed(Mbps) Health   Health
      Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
      e0a       Cluster      Cluster          up   9000  auto/100000 healthy false
      e0d       Cluster      Cluster          up   9000  auto/100000 healthy false
      Node: cluster1-02
        Ignore
      8 entries were displayed.
      Node: cluster1-03
         Ignore
      e0a       Cluster      Cluster          up   9000  auto/10000 healthy  false
      e0b       Cluster      Cluster          up   9000  auto/10000 healthy  false
      Node: cluster1-04
        Ignore
      cluster1::*>
    2. Verify that all the cluster interfaces (LIFs) are on the home port:
      network interface show -vserver Cluster
      Show example
      cluster1::*> network interface show -vserver Cluster
                  Logical            Status     Network           Current      Current Is
      Vserver     Interface          Admin/Oper Address/Mask      Node         Port    Home
      Cluster
                  cluster1-01_clus1  up/up     169.254.3.4/23     cluster1-01  e0a     true
                  cluster1-01_clus2  up/up     169.254.3.5/23     cluster1-01  e0d     true
                  cluster1-02_clus1  up/up     169.254.3.8/23     cluster1-02  e0a     true
                  cluster1-02_clus2  up/up     169.254.3.9/23     cluster1-02  e0d     true
                  cluster1-03_clus1  up/up     169.254.1.3/23     cluster1-03  e0a     true
                  cluster1-03_clus2  up/up     169.254.1.1/23     cluster1-03  e0b     true
                  cluster1-04_clus1  up/up     169.254.1.6/23     cluster1-04  e0a     true
                  cluster1-04_clus2  up/up     169.254.1.7/23     cluster1-04  e0b     true
      cluster1::*>
    3. Verify that the cluster displays information for both cluster switches:
      system cluster-switch show -is-monitoring-enabled-operational true
      Show example
      cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true
      Switch                      Type               Address          Model
      cs1                         cluster-network    10.0.0.1         NX3132QV
           Serial Number: FOXXXXXXXGS
            Is Monitored: true
                  Reason: None
        Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                          9.3(4)
          Version Source: CDP
      cs2                         cluster-network    10.0.0.2         NX3132QV
           Serial Number: FOXXXXXXXGD
            Is Monitored: true
                  Reason: None
                          9.3(4)
          Version Source: CDP
      2 entries were displayed.
    Note For ONTAP 9.8 and later, use the command system switch ethernet show -is-monitoring-enabled-operational true.
  3. Disable auto-revert on the cluster LIFs.
    cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert false
    Make sure that auto-revert is disabled after running this command.
  4. On cluster switch cs2, shut down the ports connected to the cluster ports of the nodes.
    cs2> enable
    cs2# configure
    cs2(config)# interface eth1/1/1-2,eth1/7-8
    cs2(config-if-range)# shutdown
    cs2(config-if-range)# exit
    cs2# exit
    Note The number of ports displayed varies based on the number of nodes in the cluster.
  5. Verify that the cluster ports have failed over to the ports hosted on cluster switch cs1. This might take a few seconds.
    Show example
    Cluster
                cluster1-01_clus2 up/up      169.254.3.5/23     cluster1-01   e0a     false
                cluster1-02_clus2 up/up      169.254.3.9/23     cluster1-02   e0a     false
                cluster1-03_clus2 up/up      169.254.1.1/23     cluster1-03   e0a     false
                cluster1-04_clus2 up/up      169.254.1.7/23     cluster1-04   e0a     false
    cluster1::*>
  6. Verify that the cluster is healthy:
    cluster show
    Show example
    cluster1::*> cluster show
    Node                 Health  Eligibility   Epsilon
    cluster1-01          true    true          false
    cluster1-02          true    true          false
    cluster1-03          true    true          true
    cluster1-04          true    true          false
    cluster1::*>
  7. If you have not already done so, save a copy of the current switch configuration by copying the output of the following command to a text file:
    show running-config
  8. Record any custom additions between the current running-config and the RCF file in use.
    Note
    Make sure to configure the following: * Username and password * Management IP address * Default gateway * Switch name
  9. Save basic configuration details to the write_erase.cfg file on the bootflash.
    Note When upgrading or applying a new RCF, you must erase the switch settings and perform basic configuration. You must be connected to the switch serial console port to set up the switch again.
    cs2# show run | section "switchname" > bootflash:write_erase.cfg
    cs2# show run | section "hostname" >> bootflash:write_erase.cfg
    cs2# show run | i "username admin password" >> bootflash:write_erase.cfg
    cs2# show run | section "vrf context management" >> bootflash:write_erase.cfg
    cs2# show run | section "interface mgmt0" >> bootflash:write_erase.cfg
  10. When installing RCF version 1.12 and later, run the following commands:
    cs2# echo "hardware access-list tcam region vpc-convergence 256" >> bootflash:write_erase.cfg
    cs2# echo "hardware access-list tcam region racl 256" >> bootflash:write_erase.cfg
    cs2# echo "hardware access-list tcam region e-racl 256" >> bootflash:write_erase.cfg
    cs2# echo "hardware access-list tcam region qos 256" >> bootflash:write_erase.cfg
  11. Verify that the write_erase.cfg file is populated as expected:
    show file bootflash:write_erase.cfg
  12. Issue the write erase command to erase the current saved configuration:
    cs2# write erase
    Warning: This command will erase the startup-configuration.
    Do you wish to proceed anyway? (y/n) [n] y
  13. Copy the previously saved basic configuration into the startup configuration.
    cs2# copy bootflash:write_erase.cfg startup-config
  14. Reboot the switch:
    cs2# reload
    This command will reboot the system. (y/n)? [n] y
  15. Repeat Steps 7 to 14 on switch cs1.
  16. Connect the cluster ports of all nodes in the ONTAP cluster to switches cs1 and cs2.
Step 2: Verify the switch connections
  1. Verify that the switch ports connected to the cluster ports are up.
    show interface brief | grep up
    Show example
    cs1# show interface brief | grep up
    Eth1/1/1      1       eth  access up      none                    10G(D) --
    Eth1/1/2      1       eth  access up      none                    10G(D) --
    Eth1/7        1       eth  trunk  up      none                   100G(D) --
    Eth1/8        1       eth  trunk  up      none                   100G(D) --
  2. Verify that the ISL between cs1 and cs2 is functional:
    show port-channel summary
    Show example
    cs1# show port-channel summary
    Flags:  D - Down        P - Up in port-channel (members)
            I - Individual  H - Hot-standby (LACP only)
            s - Suspended   r - Module-removed
            b - BFD Session Wait
            S - Switched    R - Routed
            U - Up (port-channel)
            p - Up in delay-lacp mode (member)
            M - Not in use. Min-links not met
    Group Port-       Type     Protocol  Member Ports
          Channel
    1     Po1(SU)     Eth      LACP      Eth1/31(P)   Eth1/32(P)
    cs1#
  3. Verify that the cluster LIFs have reverted to their home port:
    Show example
    Cluster
                cluster1-01_clus1  up/up      169.254.3.4/23     cluster1-01         e0d     true
                cluster1-02_clus1  up/up      169.254.3.8/23     cluster1-02         e0d     true
                cluster1-03_clus1  up/up      169.254.1.3/23     cluster1-03         e0b     true
                cluster1-04_clus1  up/up      169.254.1.6/23     cluster1-04         e0b     true
    cluster1::*>
  4. Verify that the cluster is healthy:
    cluster show
    Show example
    cluster1::*>
Step 3: Setup your ONTAP cluster
NetApp recommends that you use System Manager to set up new clusters.
System Manager provides a simple and easy workflow for cluster set up and configuration including assigning a node management IP address, initializing the cluster, creating a local tier, configuring protocols, and provisioning initial storage.
Refer to Configure ONTAP on a new cluster with System Manager for setup instructions.
What's next?
After you've installed the RCF, you can verify the SSH configuration.
