Upgrade the RCF on Cisco Nexus 3132Q-V cluster switches
Upgrade the reference configuration file (RCF) on Cisco Nexus 3132Q-V cluster switches when a newer version of the RCF is available.
Make sure you have the following:
A current backup of the switch configuration.
A fully functioning cluster (no errors in the logs or similar issues).
The current RCF.
If you are updating your RCF version, you need a boot configuration in the RCF that reflects the desired boot images.
If you need to change the boot configuration to reflect the current boot images, you must do so before reapplying the RCF so that the correct version is instantiated on future reboots.
No operational inter-switch link (ISL) is needed during this procedure. This is by design because RCF version changes can affect ISL connectivity temporarily. To ensure non-disruptive cluster operations, the following procedure migrates all of the cluster LIFs to the operational partner switch while performing the steps on the target switch. |
Before installing a new switch software version and RCFs, you must erase the switch settings and perform basic configuration. You must be connected to the switch using the serial console or have preserved basic configuration information prior to erasing the switch settings. |
Step 1: Prepare for the upgrade
Display the cluster ports on each node that are connected to the cluster switches:
network device-discovery showShow example
cluster1::*> network device-discovery show Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ------------ cluster1-01/cdp e0a cs1 Ethernet1/7 N3K-C3132Q-V e0d cs2 Ethernet1/7 N3K-C3132Q-V cluster1-02/cdp e0a cs1 Ethernet1/8 N3K-C3132Q-V e0d cs2 Ethernet1/8 N3K-C3132Q-V cluster1-03/cdp e0a cs1 Ethernet1/1/1 N3K-C3132Q-V e0b cs2 Ethernet1/1/1 N3K-C3132Q-V cluster1-04/cdp e0a cs1 Ethernet1/1/2 N3K-C3132Q-V e0b cs2 Ethernet1/1/2 N3K-C3132Q-V cluster1::*> -
Check the administrative and operational status of each cluster port.
Verify that all the cluster ports are up with a healthy status:
network port show -ipspace ClusterShow example
cluster1::*> network port show -ipspace Cluster Node: cluster1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false Node: cluster1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false 8 entries were displayed. Node: cluster1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false cluster1::*> -
Verify that all the cluster interfaces (LIFs) are on the home port:
network interface show -vserver ClusterShow example
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ----------------- ------------ ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0a true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0a true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0a true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0a true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true cluster1::*> -
Verify that the cluster displays information for both cluster switches:
system cluster-switch show -is-monitoring-enabled-operational trueShow example
cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- --------------- cs1 cluster-network 10.0.0.1 NX3132QV Serial Number: FOXXXXXXXGS Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(4) Version Source: CDP cs2 cluster-network 10.0.0.2 NX3132QV Serial Number: FOXXXXXXXGD Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(4) Version Source: CDP 2 entries were displayed.
For ONTAP 9.8 and later, use the command system switch ethernet show -is-monitoring-enabled-operational true. -
Disable auto-revert on the cluster LIFs.
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert false
Make sure that auto-revert is disabled after running this command.
Step 2: Configure ports
On cluster switch cs2, shut down the ports connected to the cluster ports of the nodes.
cs2> enable cs2# configure cs2(config)# interface eth1/1/1-2,eth1/7-8 cs2(config-if-range)# shutdown cs2(config-if-range)# exit cs2# exit
The number of ports displayed varies based on the number of nodes in the cluster. -
Verify that the cluster ports have failed over to the ports hosted on cluster switch cs1. This might take a few seconds.
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ----------------- ---------- ------------------ ------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0a true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0a false cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0a true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0a false cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0a true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0a false cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0a true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0a false cluster1::*> -
Verify that the cluster is healthy:
cluster showShow example
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false cluster1::*>
If you have not already done so, save a copy of the current switch configuration by copying the output of the following command to a text file:
show running-config -
Record any custom additions between the current running-config and the RCF file in use.
Make sure to configure the following:
Username and password
Management IP address
Default gateway
Switch name
Save basic configuration details to the
write_erase.cfgfile on the bootflash.When upgrading or applying a new RCF, you must erase the switch settings and perform basic configuration. cs2# show run | section "switchname" > bootflash:write_erase.cfgcs2# show run | section "hostname" >> bootflash:write_erase.cfgcs2# show run | i "username admin password" >> bootflash:write_erase.cfgcs2# show run | section "vrf context management" >> bootflash:write_erase.cfgcs2# show run | section "interface mgmt0" >> bootflash:write_erase.cfg -
When upgrading to RCF version 1.12 and later, run the following commands:
cs2# echo "hardware access-list tcam region vpc-convergence 256" >> bootflash:write_erase.cfgcs2# echo "hardware access-list tcam region racl 256" >> bootflash:write_erase.cfgcs2# echo "hardware access-list tcam region e-racl 256" >> bootflash:write_erase.cfgcs2# echo "hardware access-list tcam region qos 256" >> bootflash:write_erase.cfg -
Verify that the
write_erase.cfgfile is populated as expected:show file bootflash:write_erase.cfg -
Issue the
write erasecommand to erase the current saved configuration:cs2# write eraseWarning: This command will erase the startup-configuration.Do you wish to proceed anyway? (y/n) [n] y -
Copy the previously saved basic configuration into the startup configuration.
cs2# copy bootflash:write_erase.cfg startup-config -
Reboot the switch:
cs2# reloadThis command will reboot the system. (y/n)? [n] y -
After the management IP address is reachable again, log in to the switch through SSH.
You may need to update host file entries related to the SSH keys.
Copy the RCF to the bootflash of switch cs2 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP. For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 3000 Series NX-OS Command Reference.
Show example
cs2# copy tftp: bootflash: vrf management Enter source filename: Nexus_3132QV_RCF_v1.6-Cluster-HA-Breakout.txt Enter hostname for the tftp server: 172.22.201.50 Trying to connect to tftp server......Connection to Server Established. TFTP get operation was successful Copy complete, now saving to disk (please wait)...
Apply the RCF previously downloaded to the bootflash.
Show example
cs2# copy Nexus_3132QV_RCF_v1.6-Cluster-HA-Breakout.txt running-config echo-commands
Make sure to read thoroughly the Installation notes, Important Notes, and banner sections of your RCF. You must read and follow these instructions to ensure the proper configuration and operation of the switch.
Verify that the RCF file is the correct newer version:
show running-configWhen you check the output to verify you have the correct RCF, make sure that the following information is correct:
The RCF banner
The node and port settings
Customizations
The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
For steps on how to bring your 10GbE ports online after an upgrade of the RCF, refer to the Knowledge Base article 10GbE ports on a Cisco 3132Q cluster switch do not come online.
After you verify the RCF versions and switch settings are correct, copy the
running-configfile to thestartup-configfile.For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 3000 Series NX-OS Command Reference. .Show example
cs2# copy running-config startup-config [########################################] 100% Copy complete
Reboot switch cs2. You can ignore both the "cluster ports down" events reported on the nodes while the switch reboots and the error
% Invalid command at '^' markeroutput.cs2# reload This command will reboot the system. (y/n)? [n] y
Reapply any previous customizations to the switch configuration. Refer to Review cabling and configuration requirements for details of any further changes required.
Verify the health of cluster ports on the cluster.
Verify that cluster ports are up and healthy across all nodes in the cluster:
cluster1::*> network port show -ipspace Cluster Node: cluster1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false Node: cluster1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false -
Verify the switch health from the cluster.
network device-discovery show -protocol cdpShow example
cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ----------------- -------- cluster1-01/cdp e0a cs1 Ethernet1/7 N3K-C3132Q-V e0d cs2 Ethernet1/7 N3K-C3132Q-V cluster01-2/cdp e0a cs1 Ethernet1/8 N3K-C3132Q-V e0d cs2 Ethernet1/8 N3K-C3132Q-V cluster01-3/cdp e0a cs1 Ethernet1/1/1 N3K-C3132Q-V e0b cs2 Ethernet1/1/1 N3K-C3132Q-V cluster1-04/cdp e0a cs1 Ethernet1/1/2 N3K-C3132Q-V e0b cs2 Ethernet1/1/2 N3K-C3132Q-V cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- ----- cs1 cluster-network 10.233.205.90 N3K-C3132Q-V Serial Number: FOXXXXXXXGD Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(4) Version Source: CDP cs2 cluster-network 10.233.205.91 N3K-C3132Q-V Serial Number: FOXXXXXXXGS Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(4) Version Source: CDP 2 entries were displayed.For ONTAP 9.8 and later, use the command system switch ethernet show -is-monitoring-enabled-operational true.You might observe the following output on the cs1 switch console depending on the RCF version previously loaded on the switch:
2020 Nov 17 16:07:18 cs1 %$ VDC-1 %$ %STP-2-UNBLOCK_CONSIST_PORT: Unblocking port port-channel1 on VLAN0092. Port consistency restored. 2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_PEER: Blocking port-channel1 on VLAN0001. Inconsistent peer vlan. 2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_LOCAL: Blocking port-channel1 on VLAN0092. Inconsistent local vlan.It can take up to 5 minutes for the cluster nodes to report as healthy.
On cluster switch cs1, shut down the ports connected to the cluster ports of the nodes.
Show example
cs1> enable cs1# configure cs1(config)# interface eth1/1/1-2,eth1/7-8 cs1(config-if-range)# shutdown cs1(config-if-range)# exit cs1# exit
Verify that the cluster LIFs have migrated to the ports hosted on switch cs2. This might take a few seconds.
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ------------------ ------------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0d false cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0d false cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0b false cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0b false cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true cluster1::*> -
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- -------- ------------- ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false 4 entries were displayed. cluster1::*>
Repeat Steps 1 to 19 on switch cs1.
Enable auto-revert on the cluster LIFs.
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert True
Reboot switch cs1. You do this to trigger the cluster LIFs to revert to their home ports. You can ignore the "cluster ports down" events reported on the nodes while the switch reboots.
cs1# reload This command will reboot the system. (y/n)? [n] y
Step 3: Verify the configuration
Verify that the switch ports connected to the cluster ports are up.
show interface brief | grep upShow example
cs1# show interface brief | grep up . . Eth1/1/1 1 eth access up none 10G(D) -- Eth1/1/2 1 eth access up none 10G(D) -- Eth1/7 1 eth trunk up none 100G(D) -- Eth1/8 1 eth trunk up none 100G(D) -- . .
Verify that the ISL between cs1 and cs2 is functional:
show port-channel summaryShow example
cs1# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed b - BFD Session Wait S - Switched R - Routed U - Up (port-channel) p - Up in delay-lacp mode (member) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/31(P) Eth1/32(P) cs1# -
Verify that the cluster LIFs have reverted to their home ports:
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ------------------ ------------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0d true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0d true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0b true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0b true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true cluster1::*> -
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------- ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false cluster1::*>
Verify the connectivity of the remote cluster interfaces:
You can use the network interface check cluster-connectivity command to start an accessibility check for cluster connectivity and then display the details:
network interface check cluster-connectivity start and network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTE: Wait for a number of seconds before running the show command to display the details.
cluster1::*> network interface check cluster-connectivity show
Source Destination Packet
Node Date LIF LIF Loss
cluster1-01
3/5/2022 19:21:18 -06:00 cluster1-01_clus2 cluster1-02_clus1 none
3/5/2022 19:21:20 -06:00 cluster1-01_clus2 cluster1-02_clus2 none
cluster1-02
3/5/2022 19:21:18 -06:00 cluster1-02_clus2 cluster1-01_clus1 none
3/5/2022 19:21:20 -06:00 cluster1-02_clus2 cluster1-01_clus2 none
For all ONTAP releases, you can also use the cluster ping-cluster -node <name> command to check the connectivity:
cluster1::*> cluster ping-cluster -node local
Host is cluster1-02
Getting addresses from network interface table...
Cluster cluster1-01_clus1 169.254.209.69 cluster1-01 e0a
Cluster cluster1-01_clus2 169.254.49.125 cluster1-01 e0b
Cluster cluster1-02_clus1 169.254.47.194 cluster1-02 e0a
Cluster cluster1-02_clus2 169.254.19.183 cluster1-02 e0b
Local = 169.254.47.194 169.254.19.183
Remote = 169.254.209.69 169.254.49.125
Cluster Vserver Id = 4294967293
Ping status: ......
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s)
Detected 9000 byte MTU on 4 path(s):
Local 169.254.19.183 to Remote 169.254.209.69
Local 169.254.19.183 to Remote 169.254.49.125
Local 169.254.47.194 to Remote 169.254.209.69
Local 169.254.47.194 to Remote 169.254.49.125
Larger than PMTU communication succeeds on 4 path(s)
RPC status:
2 paths up, 0 paths down (tcp check)
2 paths up, 0 paths down (udp check)
After you've upgraded your RCF, you verify the SSH configuration.
