Install and maintain
Configure software workflow for Cisco 9332D-GX2B switches
Contributors netapp-yvonneo
To install and configure the software for a Cisco 9332D-GX2B switch and to install or upgrade the Reference Configuration File (RCF), follow these steps:
Configure the Cisco 9332D-GX2B switch.
Install the Cisco NX-OS software and reference configuration files (RCFs) on the Cisco 9332D-GX2B switches.
Download and install or upgrade the NX-OS software on the Cisco 9332D-GX2B switch.
Install or upgrade the RCF after setting up the Cisco 9332D-GX2B switch for the first time. You can also use this procedure to upgrade your RCF version.
Verify that SSH is enabled on the Cisco 9332D-GX2B switch for use with the Ethernet Switch Health Monitor (CSHM) and log collection features.
Once you have finished configuring your switches, go to Power on your AFX 1K storage system.
