Install and maintain
Install or upgrade the NX-OS software
Contributors netapp-yvonneo
Follow this procedure to install or upgrade the NX-OS software on the Nexus 9332D-GX2B switch.
Review requirements
Before you begin
Verify the following:
  • Complete the procedure in Prepare to install NX-OS and RCF.
  • A current backup of the switch configuration.
  • A fully functioning cluster (no errors in the logs or similar issues).
Suggested documentation
  • Cisco Ethernet switch page
    Consult the switch compatibility table for the supported ONTAP and NX-OS versions.
  • Software Upgrade and downgrade guides
    Refer to the appropriate software and upgrade guides available on the Cisco website for complete documentation on the Cisco switch upgrade and downgrade procedures.
  • Cisco Nexus 9000 and 3000 Upgrade and ISSU Matrix
    Provides information on Disruptive Upgrade/Downgrade for Cisco NX-OS software on Nexus 9000 Series Switches based on your current and target releases.
    On the page, select Disruptive Upgrade and select your current release and target release from the dropdown list.
About the examples
The examples in this procedure use the following switch and node nomenclature:
  • The names of the two Cisco switches are cs1 and cs2.
  • The node names are node1-01, node1-02, node1-03, and node1-04.
  • The cluster LIF names are node1-01_clus1, node1-01_clus2, node1-02_clus1, node1-02_clus2, node1-03_clus1, node1-03_clus2, node1-04_clus1, and node1-04_clus2.
  • The cluster1::*> prompt indicates the name of the cluster.
Install the software
The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
Important
  • NX-OS 10.4.2 is the only supported version for Cisco Nexus 9332D-GX2B switches in an ONTAP cluster.
  • Do not upgrade or downgrade your NX-OS version to an unsupported version; only 10.4.2 is currently supported.
Steps
  1. Connect the switch to the management network.
  2. Use the ping command to verify connectivity to the server hosting the NX-OS software and the RCF.
    Show example
    This example verifies that the switch can reach the server at IP address 172.19.2.1:
    cs2# ping 172.19.2.1
    Pinging 172.19.2.1 with 0 bytes of data:
    Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
  3. Display the cluster ports on each node that are connected to the cluster switches:
    network device-discovery show
    Show example
    cluster1::*> network device-discovery show
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID) Interface         Platform
    node1-01/cdp
                e10a   cs1(FLMXXXXXXXX)         Ethernet1/16/3    N9K-C9332D-GX2B
                e10b   cs2(FDOXXXXXXXX)         Ethernet1/16/3    N9K-C9332D-GX2B
                e11a   cs1(FLMXXXXXXXX)         Ethernet1/16/4    N9K-C9332D-GX2B
                e11b   cs2(FDOXXXXXXXX)         Ethernet1/16/4    N9K-C9332D-GX2B
                e1a    cs1(FLMXXXXXXXX)         Ethernet1/16/1    N9K-C9332D-GX2B
                e1b    cs2(FDOXXXXXXXX)         Ethernet1/16/1    N9K-C9332D-GX2B
                e7a    cs1(FLMXXXXXXXX)         Ethernet1/16/2    N9K-C9332D-GX2B
                e7b    cs2(FDOXXXXXXXX)         Ethernet1/16/2    N9K-C9332D-GX2B
    node1-01/lldp
                e10a   cs1 (c8:60:8f:xx:xx:xx)  Ethernet1/16/3    -
                e10b   cs2 (04:e3:87:xx:xx:xx)  Ethernet1/16/3    -
                e11a   cs1 (c8:60:8f:xx:xx:xx)  Ethernet1/16/4    -
                e11b   cs2 (04:e3:87:xx:xx:xx)  Ethernet1/16/4    -
                e1a    cs1 (c8:60:8f:xx:xx:xx)  Ethernet1/16/1    -
                e1b    cs2 (04:e3:87:xx:xx:xx)  Ethernet1/16/1    -
                e7a    cs1 (c8:60:8f:34:78:d3)  Ethernet1/16/2    -
                e7b    cs2 (04:e3:87:19:a2:59)  Ethernet1/16/2    -
  4. Check the administrative and operational status of each port.
    1. Cluster ports
      1. Verify that all the cluster ports are up with a healthy status:
        network port show -ipspace Cluster
        Show example
        cluster1::*> network port show -ipspace Cluster
        Node: node1-01
        Ignore
                                                          Speed(Mbps) Health   Health
        Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
        e7a       Cluster      Cluster          up   9000  auto/100000 healthy false
        e7b       Cluster      Cluster          up   9000  auto/100000 healthy false
        Node: node1-02
        Ignore
        Node: node1-03
        Ignore
        e7a       Cluster      Cluster          up   9000  auto/10000 healthy  false
        e7b       Cluster      Cluster          up   9000  auto/10000 healthy  false
        Node: node1-04
        Ignore
      2. Verify that all the cluster interfaces (LIFs) are on the home port:
        network interface show -role cluster
        Show example
        cluster1::*> network interface show -role cluster
                    Logical         Status     Network            Current   Current Is
        Vserver     Interface       Admin/Oper Address/Mask       Node      Port    Home
        Cluster
                    node1-01_clus1  up/up      169.254.36.44/16   node1-01  e7a     true
                    node1-01_clus2  up/up      169.254.7.5/16     node1-01  e7b     true
                    node1-02_clus1  up/up      169.254.197.206/16 node1-02  e7a     true
                    node1-02_clus2  up/up      169.254.195.186/16 node1-02  e7b     true
                    node1-03_clus1  up/up      169.254.192.49/16  node1-03  e7a     true
                    node1-03_clus2  up/up      169.254.182.76/16  node1-03  e7b     true
                    node1-04_clus1  up/up      169.254.59.49/16   node1-04  e7a     true
                    node1-04_clus2  up/up      169.254.62.244/16  node1-04  e7b     true
        8 entries were displayed.
      3. Verify that the cluster displays information for both cluster switches:
        system cluster-switch show -is-monitoring-enabled-operational true
        Show example
        cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true
        Switch                      Type               Address          Model
        cs2(FDOXXXXXXXX)            cluster-network    10.228.137.233   N9K-C9332D-GX2B
             Serial Number: FDOXXXXXXXX
              Is Monitored: true
                    Reason: None
          Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                            10.4(2)
            Version Source: CDP/ISDP
        cs1(FLMXXXXXXXX)             cluster-network   10.228.137.253   N9K-C9332D-GX2B
             Serial Number: FLMXXXXXXXX
              Is Monitored: true
                    Reason: None
                            10.4(2)
        2 entries were displayed.
    2. HA ports
      1. Verify that all the HA ports are up with a healthy status:
        ha interconnect status show -node <node-name>
        Show example
        cluster1::*> ha interconnect status show -node node1-01
          (system ha interconnect status show)
                               Node: node1-01
                      Link 0 Status: up
                      Link 1 Status: up
                   Is Link 0 Active: true
                   Is Link 1 Active: true
                 IC RDMA Connection: up
                               Slot: 0
                     Debug Firmware: no
        Interconnect Port 0 :
                          Port Name: e1a-17
                                MTU: 4096
                   Link Information: ACTIVE
        Interconnect Port 1 :
                          Port Name: e1b-18
                                MTU: 4096
        cluster1::*> ha interconnect status show -node node1-02
                               Node: node1-02
                      Link 0 Status: up
                      Link 1 Status: up
                               Slot: 0
                     Debug Firmware: no
                          Port Name: e1a-17
                                MTU: 4096
                          Port Name: e1b-18
                                MTU: 4096
    3. Storage ports
      1. Verify that all the storage ports are up with a healthy status:
        storage port show -port-type ENET
        Show example
        cluster1::*> storage port show -port-type ENET
                                              Speed
        Node               Port Type  Mode    (Gb/s) State    Status
        node1-01
                           e10a ENET  -          100 enabled  online
                           e10b ENET  -          100 enabled  online
                           e11a ENET  -          100 enabled  online
                           e11b ENET  -          100 enabled  online
        node1-02
        node1-03
        node1-04
        16 entries were displayed.
    4. Storage shelf ports
      1. Verify that all the storage shelf ports are up with a healthy status:
        storage shelf port show
        Show example
        cluster1::*> storage shelf port show
        Shelf ID Module State        Internal?
        1.1
               0 A      connected    false
               1 A      connected    false
               2 A      connected    false
               3 A      connected    false
               4 A      connected    false
               5 A      connected    false
               6 A      connected    false
               7 A      connected    false
               8 B      connected    false
               9 B      connected    false
              10 B      connected    false
              11 B      connected    false
              12 B      connected    false
              13 B      connected    false
              14 B      connected    false
              15 B      connected    false
      2. Verify the connection status of all the storage shelf ports:
        storage shelf port show -fields remote-device,remote-port,connector-state
        Show example
        cluster1::*> storage shelf port show -fields remote-device,remote-port,connector-state
        shelf id connector-state remote-port    remote-device
        1.1   0  connected       Ethernet1/17/1 CX9332D-cs1
        1.1   1  connected       Ethernet1/15/1 CX9364D-cs1
        1.1   2  connected       Ethernet1/17/2 CX9332D-cs1
        1.1   3  connected       Ethernet1/15/2 CX9364D-cs1
        1.1   4  connected       Ethernet1/17/3 CX9332D-cs1
        1.1   5  connected       Ethernet1/15/3 CX9364D-cs1
        1.1   6  connected       Ethernet1/17/4 CX9332D-cs1
        1.1   7  connected       Ethernet1/15/4 CX9364D-cs1
        1.1   8  connected       Ethernet1/19/1 CX9332D-cs1
        1.1   9  connected       Ethernet1/17/1 CX9364D-cs1
        1.1   10 connected       Ethernet1/19/2 CX9332D-cs1
        1.1   11 connected       Ethernet1/17/2 CX9364D-cs1
        1.1   12 connected       Ethernet1/19/3 CX9332D-cs1
        1.1   13 connected       Ethernet1/17/3 CX9364D-cs1
        1.1   14 connected       Ethernet1/19/4 CX9332D-cs1
        1.1   15 connected       Ethernet1/17/4 CX9364D-cs1
  5. Disable auto-revert on the cluster LIFs. The cluster LIFs fail over to the partner cluster switch and remain there as you perform the upgrade procedure on the targeted switch:
    network interface modify -vserver Cluster -lif * -auto-revert false
  6. Copy the NX-OS software and EPLD images to the Nexus 9332D-GX2B switch.
    Show example
    cs2# copy sftp: bootflash: vrf management
    Enter source filename: /code/nxos.10.4.2.bin
    Enter hostname for the sftp server: 172.19.2.1
    Enter username: root
    Outbound-ReKey for 172.19.2.1:22
    Inbound-ReKey for 172.19.2.1:22
    root@172.19.2.1's password:
    sftp> progress
    Progress meter enabled
    sftp> get   /code/nxos.10.4.2.bin  /bootflash/nxos.10.4.2.bin
    /code/nxos.10.4.2.bin  100% 1261MB   9.3MB/s   02:15
    sftp> exit
    Copy complete, now saving to disk (please wait)...
    Copy complete.
    Enter source filename: /code/n9000-epld.10.4.2.F.img
    Enter username: user1
    user1@172.19.2.1's password:
    sftp> progress
    sftp> get   /code/n9000-epld.10.4.2.F.img  /bootflash/n9000-epld.10.4.2.F.img
    /code/n9000-epld.10.4.2.F.img  100%  161MB   9.5MB/s   00:16
    sftp> exit
    Copy complete.
  7. Verify the running version of the NX-OS software:
    show version
    Show example
    cs2# show version
    TAC support: http://www.cisco.com/tac
    Copyright (C) 2002-2025, Cisco and/or its affiliates.
    All rights reserved.
    The copyrights to certain works contained in this software are
    owned by other third parties and used and distributed under their own
    licenses, such as open source.  This software is provided "as is," and unless
    otherwise stated, there is no warranty, express or implied, including but not
    limited to warranties of merchantability and fitness for a particular purpose.
    Certain components of this software are licensed under
    the GNU General Public License (GPL) version 2.0 or
    GNU General Public License (GPL) version 3.0  or the GNU
    Lesser General Public License (LGPL) Version 2.1 or
    Lesser General Public License (LGPL) Version 2.0.
    A copy of each such license is available at
    http://www.opensource.org/licenses/gpl-2.0.php and
    http://opensource.org/licenses/gpl-3.0.html and
    http://www.opensource.org/licenses/lgpl-2.1.php and
    http://www.gnu.org/licenses/old-licenses/library.txt.
    Software
      BIOS: version 01.14
      NXOS: version 10.4(1) [Feature Release]
      Host NXOS: version 10.4(1)
      BIOS compile time:  11/25/2024
      NXOS image file is: bootflash:///nxos64-cs.10.4.1.F.bin
      NXOS compile time:  11/30/2023 12:00:00 [12/14/2023 05:25:50]
      NXOS boot mode: LXC
    Hardware
      cisco Nexus9000 C9332D-GX2B Chassis
      Intel(R) Xeon(R) CPU D-1633N @ 2.50GHz with 32802156 kB of memory.
      Processor Board ID FLMXXXXXXXX
      Device name: cs2
      bootflash:  115802886 kB
    Kernel uptime is 5 day(s), 2 hour(s), 13 minute(s), 21 second(s)
    Last reset at 3580 usecs after Thu Jun  5 15:55:08 2025
      Reason: Reset Requested by CLI command reload
      System version: 10.4(1)
      Service:
    plugin
      Core Plugin, Ethernet Plugin
    Active Package(s):
    cs2#
  8. Install the NX-OS image.
    Installing the image file causes it to be loaded every time the switch is rebooted.
    Show example
    cs2# install all nxos bootflash:nxos.10.4.2.bin
    Installer will perform compatibility check first. Please wait.
    Installer is forced disruptive
    Verifying image bootflash:/nxos.10.4.2.bin for boot variable "nxos".
    [] 100% -- SUCCESS
    Verifying image type.
    [] 100% -- SUCCESS
    Preparing "nxos" version info using image bootflash:/nxos.10.4.2.bin.
    [] 100% -- SUCCESS
    Preparing "bios" version info using image bootflash:/nxos.10.4.2.bin.
    [] 100% -- SUCCESS
    Performing module support checks.
    [] 100% -- SUCCESS
    Notifying services about system upgrade.
    [] 100% -- SUCCESS
    Compatibility check is done:
    Module  Bootable  Impact          Install-type  Reason
      1     yes       Disruptive      Reset         Default upgrade is not hitless
    Images will be upgraded according to following table:
    Module   Image    Running-Version(pri:alt)                 New-Version         Upg-Required
      1      nxos     10.4(1)                                  10.4(2)             Yes
      1      bios     xx.xx.:xx.xx                             xxx                 No
    Switch will be reloaded for disruptive upgrade.
    Do you want to continue with the installation (y/n)? [n] y
    Install is in progress, please wait.
    Performing runtime checks.
    [] 100% -- SUCCESS
    Setting boot variables.
    [] 100% -- SUCCESS
    Performing configuration copy.
    [] 100% -- SUCCESS
    Module 1: Refreshing compact flash and upgrading bios/loader/bootrom.
    Warning: please do not remove or power off the module at this time.
    [] 100% -- SUCCESS
    Finishing the upgrade, switch will reboot in 10 seconds.
  9. Verify the new version of NX-OS software after the switch has rebooted:
    show version
    Show example
    cs2# show version
    Software
      BIOS: version 01.14
      NXOS: version 10.4(2) [Feature Release]
      Host NXOS: version 10.4(2)
      NXOS image file is: bootflash:///nxos64-cs.10.4.2.F.bin
      NXOS boot mode: LXC
    Hardware
      Device name: cs2
      System version: 10.4(2)
      Service:
    plugin
    Active Package(s):
    cs2#
  10. Upgrade the EPLD image and reboot the switch.
    Show example
    cs2# show version module 1 epld
    EPLD Device                     Version
    MI   FPGA                        0x7
    IO   FPGA                        0x17
    MI   FPGA2                       0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    cs2# install epld bootflash:n9000-epld.10.4.2.F.img module all
    Compatibility check:
    Module        Type         Upgradable        Impact    Reason
         1         SUP         Yes       disruptive  Module Upgradable
    Retrieving EPLD versions.... Please wait.
    Module  Type   EPLD              Running-Version   New-Version  Upg-Required
         1  SUP    MI FPGA           0x07              0x07         No
         1  SUP    IO FPGA           0x17              0x19         Yes
         1  SUP    MI FPGA2          0x02              0x02         No
    The above modules require upgrade.
    The switch will be reloaded at the end of the upgrade
    Do you want to continue (y/n) ?  [n] y
    Proceeding to upgrade Modules.
    Starting Module 1 EPLD Upgrade
    Module 1 : IO FPGA [Programming] : 100.00% (     64 of      64 sectors)
    Module 1 EPLD upgrade is successful.
    Module   Type  Upgrade-Result
         1   SUP   Success
    EPLDs upgraded.
  11. After the switch reboot, log in again and verify that the new version of EPLD loaded successfully.
    Show example
    EPLD Device                     Version
    MI   FPGA                        0x7
    IO   FPGA                        0x19
    MI   FPGA2                       0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
  12. Verify the health of all the ports on the cluster.
    1. Cluster ports
      1. Verify that cluster ports are up and healthy across all nodes in the cluster:
        Show example
        Node: node1-01
        Ignore
        Node: node1-02
        Ignore
        Node: node1-03
        Ignore
        Node: node1-04
        Ignore
      2. Verify the switch health from the cluster:
        network device-discovery show -protocol cdp
        Show example
        cluster1::*> network device-discovery show -protocol cdp
        node1-02/cdp
                    e7a    cs1(FLM284504N6)         Ethernet1/16/2    N9K-C9332D-GX2B
                    e7b    cs2(FDO2846056X)         Ethernet1/16/2    N9K-C9332D-GX2B
        node1-01/cdp
              Is Monitored: true
                    Reason: None
                            10.4(2)
              Is Monitored: true
                    Reason: None
                            10.4(2)
    2. HA ports
        Show example
                               Node: node1-01
                      Link 0 Status: up
                      Link 1 Status: up
                               Slot: 0
                     Debug Firmware: no
                          Port Name: e1a-17
                                MTU: 4096
                          Port Name: e1b-18
                                MTU: 4096
                               Node: node1-02
                      Link 0 Status: up
                      Link 1 Status: up
                               Slot: 0
                     Debug Firmware: no
                          Port Name: e1a-17
                                MTU: 4096
                          Port Name: e1b-18
                                MTU: 4096
    3. Storage ports
        Show example
                                              Speed
        node1-01
        node1-02
        node1-03
        node1-04
        Show example
        1.1
               0 A      connected    false
               1 A      connected    false
               2 A      connected    false
               3 A      connected    false
               4 A      connected    false
               5 A      connected    false
               6 A      connected    false
               7 A      connected    false
               8 B      connected    false
               9 B      connected    false
        Show example
  13. Verify that the cluster is healthy:
    cluster show
    Show example
    cluster1::*> cluster show
    Node                 Health  Eligibility   Epsilon
    node1-01             true    true          false
    node1-02             true    true          false
    node1-03             true    true          false
    node1-04             true    true          true
    4 entries were displayed.
  14. Repeat steps 6 to 13 to install the NX-OS software and EPLD images on switch cs1.
  15. Enable auto-revert on the cluster LIFs.
    network interface modify -vserver Cluster -lif * -auto-revert true
  16. Verify that the cluster LIFs have reverted to their home port:
    Show example
    Cluster
    If any cluster LIFs have not returned to their home ports, revert them manually from the local node:
    network interface revert -vserver Cluster -lif <lif-name>
What's next?
After you've installed or upgraded the NX-OS software, you can install or upgrade the Reference Configuration File (RCF).
