Install and maintain
Installation and setup workflow for Cisco 9332D-GX2B switches
Contributors netapp-yvonneo
The Cisco 9332D-GX2B switch is part of the Cisco Nexus 9000 platform. The AFX systems switches allow you to build ONTAP clusters with more than two nodes.
Follow these workflow steps to install and setup your to Cisco 9332D-GX2B switches.
Review the port details for the Cisco 9332D-GX2B switch.
Review specific switch and controller documentation to set up your 9332D-GX2B switches and the ONTAP cluster.
Review the requirements for the Cisco Smart Call Home feature, used to monitor the hardware and software components on your network.
Install the switch hardware.
Configure the switch software.
Configure switch health monitoring.
