Replace a Cisco Nexus 9332D-GX2B switch in an AFX system
Replace a defective Cisco Nexus 9332D-GX2B switch in an AFX system without disrupting operation. This nondisruptive procedure (NDU) involves preparing a replacement switch and restoring the system configuration.
Review requirements
Before performing the switch replacement, make sure that:
You have verified the switch serial number to ensure that the correct switch is replaced.
On the existing cluster and network infrastructure:
The existing cluster is verified as completely functional, with at least one fully connected cluster switch.
All cluster ports are up.
All cluster logical interfaces (LIFs) are up and on their home ports.
The ONTAP
cluster ping-cluster -node <node-name>command must indicate that basic connectivity and larger than PMTU communication are successful on all paths.
On the Nexus 9332D-GX2B replacement switch:
Management network connectivity on the replacement switch is functional.
Console access to the replacement switch is in place.
The node connections are ports 1/1 through 1/30.
All Inter-Switch Link (ISL) ports is disabled on ports 1/31 and 1/32.
The desired reference configuration file (RCF) and NX-OS operating system image switch is loaded onto the switch.
Initial customization of the switch is complete, as detailed in Complete initial switch setup.
Any previous site customizations, such as STP, SNMP, and SSH, are copied to the new switch.
You have executed the command for migrating a cluster LIF from the node where the cluster LIF is hosted.
Enable console logging
NetApp strongly recommends that you enable console logging on the devices that you are using and take the following actions when replacing your switch:
Leave AutoSupport enabled during maintenance.
Trigger a maintenance AutoSupport before and after maintenance to disable case creation for the duration of the maintenance. Refer to this Knowledge Base article SU92: How to suppress automatic case creation during scheduled maintenance windows for further details.
Enable session logging for any CLI sessions. For instructions on how to enable session logging, review the "Logging Session Output" section in this Knowledge Base article How to configure PuTTY for optimal connectivity to ONTAP systems.
Replace the switch
The examples in this procedure use the following switch and node nomenclature:
The names of the existing Nexus 9332D-GX2B switches are cs1 and cs2.
The name of the new Nexus 9332D-GX2B switch is newcs2.
The node names are node1-01, node1-02, node1-03, and node1-04.
The cluster LIF names are node1-01_clus1 and node1-01_clus2 for node1-01, node1-02_clus1 and node1-02_clus2 for node1-02, node1-03_clus1 and node1-03_clus2 for node1-03, and node1-04_clus1 and node1-04_clus2 for node1-04.
The prompt for changes to all cluster nodes is cluster1::*>
The following procedure is based on the following cluster network topology:
Show example
cluster1::*> network port show -ipspace Cluster
Node: node1-01
Ignore
Speed(Mbps) Health Health
Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status
e7a Cluster Cluster up 9000 auto/100000 healthy false
e7b Cluster Cluster up 9000 auto/100000 healthy false
Node: node1-02
Ignore
Node: node1-03
Ignore
Node: node1-04
Ignore
8 entries were displayed.
cluster1::*> network interface show -vserver Cluster
Logical Status Network Current Current Is
Vserver Interface Admin/Oper Address/Mask Node Port Home
Cluster
node1-01_clus1 up/up 169.254.36.44/16 node1-01 e7a true
node1-01_clus2 up/up 169.254.7.5/16 node1-01 e7b true
node1-02_clus1 up/up 169.254.197.206/16 node1-02 e7a true
node1-02_clus2 up/up 169.254.195.186/16 node1-02 e7b true
node1-03_clus1 up/up 169.254.192.49/16 node1-03 e7a true
node1-03_clus2 up/up 169.254.182.76/16 node1-03 e7b true
node1-04_clus1 up/up 169.254.59.49/16 node1-04 e7a true
node1-04_clus2 up/up 169.254.62.244/16 node1-04 e7b true
cluster1::*> network device-discovery show -protocol cdp
Node/ Local Discovered
Protocol Port Device (LLDP: ChassisID) Interface Platform
node1-01/cdp
e10a cs1(FLMXXXXXXXX) Ethernet1/16/3 N9K-C9332D-GX2B
e10b cs2(FDOXXXXXXXX) Ethernet1/16/3 N9K-C9332D-GX2B
e11a cs1(FLMXXXXXXXX) Ethernet1/16/4 N9K-C9332D-GX2B
e11b cs2(FDOXXXXXXXX) Ethernet1/16/4 N9K-C9332D-GX2B
e1a cs1(FLMXXXXXXXX) Ethernet1/16/1 N9K-C9332D-GX2B
e1b cs2(FDOXXXXXXXX) Ethernet1/16/1 N9K-C9332D-GX2B
e7a cs1(FLMXXXXXXXX) Ethernet1/16/2 N9K-C9332D-GX2B
e7b cs2(FDOXXXXXXXX) Ethernet1/16/2 N9K-C9332D-GX2B
cs1# show cdp neighbors
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
S - Switch, H - Host, I - IGMP, r - Repeater,
V - VoIP-Phone, D - Remotely-Managed-Device,
s - Supports-STP-Dispute
Device-ID Local Intrfce Hldtme Capability Platform Port ID
cs2(FDOXXXXXXXX) Eth1/31 179 R S I s N9K-C9364D-GX2A Eth1/63
cs2(FDOXXXXXXXX) Eth1/32 179 R S I s N9K-C9364D-GX2A Eth1/64
node1-01 Eth1/4/1 123 H AFX-1K e1a
node1-01 Eth1/4/2 123 H AFX-1K e7a
node1-01 Eth1/4/3 123 H AFX-1K e10a
node1-01 Eth1/4/4 123 H AFX-1K e11a
node1-02 Eth1/9/1 138 H AFX-1K e1a
node1-02 Eth1/9/2 138 H AFX-1K e7a
node1-02 Eth1/9/3 138 H AFX-1K e10a
node1-02 Eth1/9/4 138 H AFX-1K e11a
node1-03 Eth1/15/1 138 H AFX-1K e1a
node1-03 Eth1/15/2 138 H AFX-1K e7a
node1-03 Eth1/15/3 138 H AFX-1K e10a
node1-03 Eth1/15/4 138 H AFX-1K e11a
node1-04 Eth1/16/1 173 H AFX-1K e1a
node1-04 Eth1/16/2 173 H AFX-1K e7a
node1-04 Eth1/16/3 173 H AFX-1K e10a
node1-04 Eth1/16/4 173 H AFX-1K e11a
Total entries displayed: 18
cs2# show cdp neighbors
cs1(FLMXXXXXXXX) Eth1/31 179 R S I s N9K-C9364D-GX2A Eth1/63
cs1(FLMXXXXXXXX) Eth1/32 179 R S I s N9K-C9364D-GX2A Eth1/64
Step 1: Prepare for replacement
If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=xhwhere x is the duration of the maintenance window in hours.
The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window. -
Install the appropriate RCF and image on the switch, newcs2, and make any necessary site preparations.
If necessary, verify, download, and install the appropriate versions of the RCF and NX-OS software for the new switch. If you have verified that the new switch is correctly set up and does not need updates to the RCF and NX-OS software, continue to step 2.
Go to the NetApp Cluster and Management Network Switches Reference Configuration File Description Page on the NetApp Support Site.
Click the link for the Cluster Network and Management Network Compatibility Matrix, and then note the required switch software version.
Click your browser's back arrow to return to the Description page, click CONTINUE, accept the license agreement, and then go to the Download page.
Follow the steps on the Download page to download the correct RCF and NX-OS files for the version of ONTAP software you are installing.
On the new switch, log in as admin and shut down all of the ports that will be connected to the node cluster interfaces (ports 1/1 to 1/30).
If the switch that you are replacing is not functional and is powered down, go to Step 4. The LIFs on the cluster nodes should have already failed over to the other cluster port for each node.
Show example
newcs2# config newcs2(config)# interface e1/1/1-4,e1/2/1-4,e1/3/1-4,e1/4/1-4,e1/5/1-4,e1/6/1-4,e1/7/1-4,e1/8/1-4 newcs2(config-if-range)# shutdown newcs2(config)# interface e1/9/1-4,e1/10/1-4,e1/11/1-4,e1/12/1-4,e1/13/1-4,e1/14/1-4,e1/15/1-4,e1/16/1-4 newcs2(config-if-range)# shutdown newcs2(config)# interface e1/17/1-4,e1/18/1-4,e1/19/1-4,e1/20/1-4,e1/21/1-4,e1/22/1-4,e1/23/1-4 newcs2(config-if-range)# shutdown newcs2(config)# interface e1/24/1-4,e1/25/1-4,e1/26/1-4,e1/27/1-4,e1/28/1-4,e1/29/1-4,e1/30/1-4 newcs2(config-if-range)# shutdown newcs2(config-if-range)# exit newcs2(config)# exit
Verify that all cluster LIFs have auto-revert enabled:
network interface show -vserver Cluster -fields auto-revertShow example
cluster1::> network interface show -vserver Cluster -fields auto-revert Logical Vserver Interface Auto-revert ------------ ---------------- ------------- Cluster node1-01_clus1 true Cluster node1-02_clus2 true Cluster node1-03_clus1 true Cluster node1-04_clus2 true 4 entries were displayed. -
Verify the connectivity of the remote cluster interfaces:
You can use the
network interface check cluster-connectivity showcommand to display the details of an accessibility check for cluster connectivity:network interface check cluster-connectivity showShow example
cluster1::*> network interface check cluster-connectivity show Source Destination Packet Node Date LIF LIF Loss --------- -------------------------- --------------- --------------- ----------- node1-01 6/4/2025 03:13:33 -04:00 node1-01_clus2 node1-02_clus1 none 6/4/2025 03:13:34 -04:00 node1-01_clus2 node1-02_clus2 none node1-02 6/4/2025 03:13:33 -04:00 node1-02_clus2 node1-01_clus1 none 6/4/2025 03:13:34 -04:00 node1-02_clus2 node1-01_clus2 none . . . -
Alternatively, you can also use the
cluster ping-cluster -node <node-name>command to check the connectivity:cluster ping-cluster -node <node-name>Show example
cluster1::*> cluster ping-cluster -node local Host is node2 Getting addresses from network interface table... Cluster node1_clus1 169.254.209.69 node1 e0a Cluster node1_clus2 169.254.49.125 node1 e0b Cluster node2_clus1 169.254.47.194 node2 e0a Cluster node2_clus2 169.254.19.183 node2 e0b Local = 169.254.47.194 169.254.19.183 Remote = 169.254.209.69 169.254.49.125 Cluster Vserver Id = 4294967293 Ping status: .... Basic connectivity succeeds on 4 path(s) Basic connectivity fails on 0 path(s) ................ Detected 9000 byte MTU on 4 path(s): Local 169.254.47.194 to Remote 169.254.209.69 Local 169.254.47.194 to Remote 169.254.49.125 Local 169.254.19.183 to Remote 169.254.209.69 Local 169.254.19.183 to Remote 169.254.49.125 Larger than PMTU communication succeeds on 4 path(s) RPC status: 2 paths up, 0 paths down (tcp check) 2 paths up, 0 paths down (udp check)
Step 2: Configure cables and ports
Shut down the ISL ports Eth1/31 and Eth1/32 on the Nexus 9332D-GX2B switch cs1.
cs1# config Enter configuration commands, one per line. End with CNTL/Z. cs1(config)# interface e1/31-32 cs1(config-if-range)# shutdown cs1(config-if-range)# exit cs1(config)# exit
Remove all of the cables from the Nexus 9332D-GX2B cs2 switch, and then connect them to the same ports on the 9332D-GX2B newcs2 switch.
Bring up the ISLs ports Eth1/31 and Eth1/32 between the cs1 and newcs2 switches, and then verify the port channel operation status.
Port-Channel should indicate Po1(SU) and Member Ports should indicate Eth1/31(P) and Eth1/32(P).
Show example
This example enables ISL ports Eth1/31 and Eth1/32 and displays the port channel summary on switch cs1:
cs1# config Enter configuration commands, one per line. End with CNTL/Z. cs1(config)# int e1/31-32 cs1(config-if-range)# no shutdown cs1(config-if-range)# exit cs1(config)# exit cs1# cs1# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed b - BFD Session Wait S - Switched R - Routed U - Up (port-channel) p - Up in delay-lacp mode (member) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/31(P) Eth1/32(P) 999 Po999(SD) Eth NONE -- -
Bring up all of the ports, Eth1/1 to Eth1/30, on the newcs2 switch.
Show example
newcs2# config newcs2(config)# interface e1/1/1-4,e1/2/1-4,e1/3/1-4,e1/4/1-4,e1/5/1-4,e1/6/1-4,e1/7/1-4,e1/8/1-4 newcs2(config-if-range)# no shutdown newcs2(config)# interface e1/9/1-4,e1/10/1-4,e1/11/1-4,e1/12/1-4,e1/13/1-4,e1/14/1-4,e1/15/1-4,e1/16/1-4 newcs2(config-if-range)# no shutdown newcs2(config)# interface e1/17/1-4,e1/18/1-4,e1/19/1-4,e1/20/1-4,e1/21/1-4,e1/22/1-4,e1/23/1-4 newcs2(config-if-range)# no shutdown newcs2(config)# interface e1/24/1-4,e1/25/1-4,e1/26/1-4,e1/27/1-4,e1/28/1-4,e1/29/1-4,e1/30/1-4 newcs2(config-if-range)# no shutdown newcs2(config-if-range)# exit newcs2(config)# exit
Verify that port e7b is up on all nodes:
network port show ipspace ClusterShow example
The output should be similar to the following:
cluster1::*> network port show -ipspace Cluster Node: node1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false Node: node1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false Node: node1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false Node: node1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false 8 entries were displayed. -
On the same node you used in the previous step, revert the cluster LIF associated with the port in the previous step by using the network interface revert command.
Show example
In this example, LIF node1-01_clus2 on node1-01 is successfully reverted if the Home value is true and the port is e7b.
The following commands return LIF
node1-01_clus2onnode1-01to home porte7aand displays information about the LIFs on both nodes. Bringing up the first node is successful if the Is Home column is true for both cluster interfaces and they show the correct port assignments, in this examplee7aande7bon node1-01.cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home --------- -------------- ---------- ------------------ ---------- ------- ----- Cluster node1-01_clus1 up/up 169.254.209.69/16 node1-01 e7a true node1-01_clus2 up/up 169.254.49.125/16 node1-01 e7b true node1-02_clus1 up/up 169.254.47.194/16 node1-02 e7b true node1-02_clus2 up/up 169.254.19.183/16 node1-02 e7a false . . . -
Display information about the nodes in a cluster:
cluster showShow example
This example shows that the node health for node1 and node2 in this cluster is true:
cluster1::*> cluster show Node Health Eligibility -------------- ------- ------------ node1-01 false true node1-02 true true node1-03 true true node1-04 true true
Verify that all physical cluster ports are up:
cluster1::*> network port show -ipspace Cluster Node: node1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false Node: node1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false . . . -
You can use the
network interface check cluster-connectivitycommand to display the details of an accessibility check for cluster connectivity:network interface check cluster-connectivity startShow example
Step 3: Verify the configuration
Verify the health of all the ports on the cluster.
Cluster ports
Verify that cluster ports are up and healthy across all nodes in the cluster:
network port show ipspace Clusternetwork interface show -vserver Clusternetwork device-discovery show -protocol cdpshow cdp neighborsShow example
cluster1::*> network port show -ipspace Cluster Node: node1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false Node: node1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false Node: node1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false Node: node1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e7a Cluster Cluster up 9000 auto/100000 healthy false e7b Cluster Cluster up 9000 auto/100000 healthy false 8 entries were displayed. cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home --------- ------------- ---------- ------------------ ---------- ------- ---- Cluster node1-01_clus1 up/up 169.254.209.69/16 node1-01 e7a true node1-01_clus2 up/up 169.254.49.125/16 node1-01 e7b true node1-02_clus1 up/up 169.254.47.194/16 node1-02 e7b true node1-02_clus2 up/up 169.254.19.183/16 node1-02 e7a true node1-03_clus1 up/up 169.254.209.69/16 node1-03 e7a true node1-03_clus2 up/up 169.254.49.125/16 node1-03 e7b true node1-04_clus1 up/up 169.254.47.194/16 node1-04 e7b true node1-04_clus2 up/up 169.254.19.183/16 node1-04 e7a false 8 entries were displayed. cluster1::> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ---------------- node1-01/cdp e10a cs1(FLMXXXXXXXX) Ethernet1/16/3 N9K-C9332D-GX2B e10b cs2(FDOXXXXXXXX) Ethernet1/16/3 N9K-C9332D-GX2B e11a cs1(FLMXXXXXXXX) Ethernet1/16/4 N9K-C9332D-GX2B e11b cs2(FDOXXXXXXXX) Ethernet1/16/4 N9K-C9332D-GX2B e1a cs1(FLMXXXXXXXX) Ethernet1/16/1 N9K-C9332D-GX2B e1b cs2(FDOXXXXXXXX) Ethernet1/16/1 N9K-C9332D-GX2B . . . e7a cs1(FLMXXXXXXXX) Ethernet1/16/2 N9K-C9332D-GX2B e7b cs2(FDOXXXXXXXX) Ethernet1/16/2 N9K-C9332D-GX2B . . . cs1# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID newcs2(FDOXXXXXXXX) Eth1/31 179 R S I s N9K-C9364D-GX2A Eth1/63 newcs2(FDOXXXXXXXX) Eth1/32 179 R S I s N9K-C9364D-GX2A Eth1/64 node1-01 Eth1/4/1 123 H AFX-1K e1a node1-01 Eth1/4/2 123 H AFX-1K e7a node1-01 Eth1/4/3 123 H AFX-1K e10a node1-01 Eth1/4/4 123 H AFX-1K e11a node1-02 Eth1/9/1 138 H AFX-1K e1a node1-02 Eth1/9/2 138 H AFX-1K e7a node1-02 Eth1/9/3 138 H AFX-1K e10a node1-02 Eth1/9/4 138 H AFX-1K e11a node1-03 Eth1/15/1 138 H AFX-1K e1a node1-03 Eth1/15/2 138 H AFX-1K e7a node1-03 Eth1/15/3 138 H AFX-1K e10a node1-03 Eth1/15/4 138 H AFX-1K e11a node1-04 Eth1/16/1 173 H AFX-1K e1a node1-04 Eth1/16/2 173 H AFX-1K e7a node1-04 Eth1/16/3 173 H AFX-1K e10a node1-04 Eth1/16/4 173 H AFX-1K e11a Total entries displayed: 18 newcs2# show cdp neighbors Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge S - Switch, H - Host, I - IGMP, r - Repeater, V - VoIP-Phone, D - Remotely-Managed-Device, s - Supports-STP-Dispute Device-ID Local Intrfce Hldtme Capability Platform Port ID cs1(FDOXXXXXXXX) Eth1/31 179 R S I s N9K-C9364D-GX2A Eth1/63 cs1(FDOXXXXXXXX) Eth1/32 179 R S I s N9K-C9364D-GX2A Eth1/64 node1-01 Eth1/4/1 123 H AFX-1K e1a node1-01 Eth1/4/2 123 H AFX-1K e7a node1-01 Eth1/4/3 123 H AFX-1K e10a node1-01 Eth1/4/4 123 H AFX-1K e11a node1-02 Eth1/9/1 138 H AFX-1K e1a node1-02 Eth1/9/2 138 H AFX-1K e7a node1-02 Eth1/9/3 138 H AFX-1K e10a node1-02 Eth1/9/4 138 H AFX-1K e11a node1-03 Eth1/15/1 138 H AFX-1K e1a node1-03 Eth1/15/2 138 H AFX-1K e7a node1-03 Eth1/15/3 138 H AFX-1K e10a node1-03 Eth1/15/4 138 H AFX-1K e11a node1-04 Eth1/16/1 173 H AFX-1K e1a node1-04 Eth1/16/2 173 H AFX-1K e7a node1-04 Eth1/16/3 173 H AFX-1K e10a node1-04 Eth1/16/4 173 H AFX-1K e11a Total entries displayed: 18
HA ports
Verify that all the HA ports are up with a healthy status:
ha interconnect status show -node <node-name>Show example
cluster1::*> ha interconnect status show -node node1-01 (system ha interconnect status show) Node: node1-01 Link 0 Status: up Link 1 Status: up Is Link 0 Active: true Is Link 1 Active: true IC RDMA Connection: up Slot: 0 Debug Firmware: no Interconnect Port 0 : Port Name: e1a-17 MTU: 4096 Link Information: ACTIVE Interconnect Port 1 : Port Name: e1b-18 MTU: 4096 Link Information: ACTIVE cluster1::*> ha interconnect status show -node node1-02 (system ha interconnect status show) Node: node1-02 Link 0 Status: up Link 1 Status: up Is Link 0 Active: true Is Link 1 Active: true IC RDMA Connection: up Slot: 0 Debug Firmware: no Interconnect Port 0 : Port Name: e1a-17 MTU: 4096 Link Information: ACTIVE Interconnect Port 1 : Port Name: e1b-18 MTU: 4096 Link Information: ACTIVE . . .
Storage ports
Verify that all the storage ports are up with a healthy status:
storage port show -port-type ENETShow example
cluster1::*> storage port show -port-type ENET Speed Node Port Type Mode (Gb/s) State Status ------------------ ---- ----- ------- ------ -------- ----------- node1-01 e10a ENET - 100 enabled online e10b ENET - 100 enabled online e11a ENET - 100 enabled online e11b ENET - 100 enabled online node1-02 e10a ENET - 100 enabled online e10b ENET - 100 enabled online e11a ENET - 100 enabled online e11b ENET - 100 enabled online node1-03 e10a ENET - 100 enabled online e10b ENET - 100 enabled online e11a ENET - 100 enabled online node1-04 e10a ENET - 100 enabled online e10b ENET - 100 enabled online e11a ENET - 100 enabled online e11b ENET - 100 enabled online 16 entries were displayed.
Storage shelf ports
Verify that all the storage shelf ports are up with a healthy status:
storage shelf port showShow example
cluster1::*> storage shelf port show Shelf ID Module State Internal? ----- -- ------ ------------ --------- 1.1 0 A connected false 1 A connected false 2 A connected false 3 A connected false 4 A connected false 5 A connected false 6 A connected false 7 A connected false 8 B connected false 9 B connected false 10 B connected false 11 B connected false 12 B connected false 13 B connected false 14 B connected false 15 B connected false 16 entries were displayed. -
Verify the connection status of all the storage shelf ports:
storage shelf port show -fields remote-device,remote-port,connector-stateShow example
cluster1::*> storage shelf port show -fields remote-device,remote-port,connector-state shelf id connector-state remote-port remote-device ----- -- --------------- -------------- ----------------- 1.1 0 connected Ethernet1/17/1 CX9332D-cs1 1.1 1 connected Ethernet1/15/1 CX9364D-cs1 1.1 2 connected Ethernet1/17/2 CX9332D-cs1 1.1 3 connected Ethernet1/15/2 CX9364D-cs1 1.1 4 connected Ethernet1/17/3 CX9332D-cs1 1.1 5 connected Ethernet1/15/3 CX9364D-cs1 1.1 6 connected Ethernet1/17/4 CX9332D-cs1 1.1 7 connected Ethernet1/15/4 CX9364D-cs1 1.1 8 connected Ethernet1/19/1 CX9332D-cs1 1.1 9 connected Ethernet1/17/1 CX9364D-cs1 1.1 10 connected Ethernet1/19/2 CX9332D-cs1 1.1 11 connected Ethernet1/17/2 CX9364D-cs1 1.1 12 connected Ethernet1/19/3 CX9332D-cs1 1.1 13 connected Ethernet1/17/3 CX9364D-cs1 1.1 14 connected Ethernet1/19/4 CX9332D-cs1 1.1 15 connected Ethernet1/17/4 CX9364D-cs1 16 entries were displayed.
If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message:
After you've replaced your switches, you configure switch health monitoring.
