Learn about installing or upgrading the RCF on Cisco Nexus 9336C-FX2 storage switches
Install the reference configuration file (RCF) on Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches after initial setup, or upgrade your RCF version when a newer version is available.
Refer to the Knowledge Base article How to clear configuration on a Cisco interconnect switch while retaining remote connectivity for further information when installing or upgrading your RCF.
Storage - (Storage RCF 1.xx) is the available RCF configuration where all ports are configured for 100GbE NVMe storage connections.
Consult the switch compatibility table for the supported ONTAP and RCF versions on the NetApp Support Site. Note that there can be command dependencies between the command syntax in the RCF and the syntax found in specific versions of NX-OS.
Cisco Nexus 9000 Series Switches
Refer to the appropriate software and upgrade guides available on the Cisco website for complete documentation on the Cisco switch upgrade and downgrade procedures.
The examples in this procedure use the following switch and node nomenclature:
The names of the two Cisco switches are s1 and s2.
The node names are cluster1-01 and cluster1-02.
Refer to the Hardware Universe to verify the correct ports on your platform.
The command outputs might vary depending on different releases of ONTAP. |
The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
After you've reviewed the install RCF or upgrade RCF procedure, you can install the RCF or upgrade your RCF as needed.
