Upgrade the RCF on Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches
Upgrade the reference configuration file (RCF) on Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches when a newer version of the RCF is available.
Make sure you have the following:
A current backup of the switch configuration.
A fully functioning cluster (no errors in the logs or similar issues).
The current RCF.
If you are updating your RCF version, you need a boot configuration in the RCF that reflects the desired boot images.
If you need to change the boot configuration to reflect the current boot images, you must do so before reapplying the RCF so that the correct version is instantiated on future reboots.
Before installing a new switch software version and RCFs, you must erase the switch settings and perform basic configuration. You must be connected to the switch using the serial console or have preserved basic configuration information before erasing the switch settings. |
Step 1: Prepare for the upgrade
If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=xhWhere x is the duration of the maintenance window in hours.
Change the privilege level to advanced, entering y when prompted to continue:
set -privilege advancedThe advanced prompt (*>) appears.
Display the ports on each node that are connected to the switches:
network device-discovery showShow example
cluster1::*> network device-discovery show Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------ --------------- --------- cluster1-01/cdp e5a s1 Ethernet1/7 N9K-C9336C e3b s2 Ethernet1/7 N9K-C9336C cluster1-02/cdp e5a s1 Ethernet1/8 N9K-C9336C e3b s2 Ethernet1/8 N9K-C9336C . . . -
Check the administrative or operational status of each node storage port and storage shelf port.
Verify that all the node storage ports are up with a healthy status:
storage port show -port-type ENETShow example
cluster1::*> storage port show -port-type ENET Speed Node Port Type Mode (Gb/s) State Status ------------------ ---- ----- ------- ------ -------- ----------- cluster1-01 e5a ENET - 100 enabled online e3b ENET - 100 enabled online cluster1-02 e5a ENET - 100 enabled online e3b ENET - 100 enabled online . . -
Verify that all the storage shelf ports are up with a healthy status:
storage shelf port showShow example
cluster1::> storage shelf port show Shelf ID Module State Internal? ----- -- ------ ------------ --------- 1.4 0 A connected false 1 A connected false 2 B connected false 3 B connected false . . -
Verify that the switches are being monitored.
system switch ethernet showShow example
cluster1::*> system switch ethernet show Switch Type Address Model ----------------- ------------------ ---------------- --------------- s1 storage-network 1.2.3.4 N9K-C9336C-FX2 Serial Number: FFFXXXXXXX1 Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.3(4a) Version Source: CDP/ISDP s2 storage-network 2.3.4.5 N9K-C9336C-FX2 Serial Number: FEEXXXXXXX2 Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.3(4a) Version Source: CDP/ISDP
Step 2: Upgrade the RCF
Log in to the switch s2 using SSH or by using a serial console.
Shut down the ports connected to all the ports of the nodes.
s2> enable s2# configure s2(config)# interface e1/1-36 s2(config-if-range)# shutdown s2(config-if-range)# exit s2(config)# exit
Make sure to shutdown all connected ports to avoid any network connection issues. Refer to the Knowledge Base article Node out of quorum when migrating cluster LIF during switch OS upgrade for further details. -
If you have not already done so, save a copy of the current switch configuration by copying the output of the following command to a text file:
show running-config-
Record any custom additions between the current
running-configand the RCF file in use (such as an SNMP configuration for your organization). -
For NX-OS 10.2 and later, use the
show diff running-configcommand to compare with the saved RCF file in the bootflash. Otherwise, use a third-party diff or compare tool.
Save basic configuration details to the
write_erase.cfgfile on the bootflash.Make sure to configure the following:
Username and password
Management IP address
Default gateway
Switch name
s2# show run | i "username admin password" > bootflash:write_erase.cfgs2# show run | section "vrf context management" >> bootflash:write_erase.cfgs2# show run | section "interface mgmt0" >> bootflash:write_erase.cfgs2# show run | section "switchname" >> bootflash:write_erase.cfgRefer to the Knowledge Base article How to clear configuration on a Cisco interconnect switch while retaining remote connectivity for further details.
Verify that the
write_erase.cfgfile is populated as expected:show file bootflash:write_erase.cfg -
Issue the
write erasecommand to erase the current saved configuration:s2# write eraseWarning: This command will erase the startup-configuration.Do you wish to proceed anyway? (y/n) [n] y -
Copy the previously saved basic configuration into the startup configuration.
s2# copy bootflash:write_erase.cfg startup-config -
Reboot the switch:
s2# reloadThis command will reboot the system. (y/n)? [n] y -
After the management IP address is reachable again, log in to the switch through SSH.
You might need to update host file entries related to the SSH keys.
Copy the RCF to the bootflash of switch s2 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP.
For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference.
Show example
This example shows TFTP being used to copy an RCF to the bootflash on switch s2:
s2# copy tftp: bootflash: vrf management Enter source filename: NX9336C-FX2-RCF-v1.13-1-Storage.txt Enter hostname for the tftp server: 172.22.201.50 Trying to connect to tftp server......Connection to Server Established. TFTP get operation was successful Copy complete, now saving to disk (please wait)...
Apply the RCF previously downloaded to the bootflash.
This example shows the RCF file
NX9336C-FX2-RCF-v1.13-1-Storage.txtbeing installed on switch s2:s2# copy NX9336C-FX2-RCF-v1.13-1-Storage.txt running-config echo-commands
Make sure to thoroughly read the Installation notes, Important Notes, and banner sections of your RCF. You must read and follow these instructions to ensure the proper configuration and operation of the switch.
Verify that the RCF file is the correct newer version:
show running-configWhen you check the output to verify you have the correct RCF, make sure that the following information is correct:
The RCF banner
The node and port settings
Customizations
The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
Reapply any previous customizations to the switch configuration.
After you verify the RCF versions, custom additions, and switch settings are correct, copy the
running-configfile to thestartup-configfile.For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference.
s2# copy running-config startup-config[] 100% Copy complete -
Reboot switch s2. You can ignore the “cluster switch health monitor” alerts and “cluster ports down” events reported on the nodes while the switch reboots.
Verify that all the storage ports are up with a healthy status:
Verify that the switches are being monitored:
cluster1::> system switch ethernet show Switch Type Address Model ---------------- ------------------ ---------------- --------------- s1 storage-network 1.2.3.4 N9K-C9336C-FX2 Serial Number: FFFXXXXXXX1 Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.3(4a) Version Source: CDP/ISDP s2 storage-network 2.3.4.5 N9K-C9336C-FX2 Serial Number: FEEXXXXXXX2 Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 10.3(4a) Version Source: CDP/ISDP
Repeat steps 1 to 16 on switch s1.
Step 3: Verify the storage network
Complete the following steps on each storage switch to verify that the storage network is functioning properly after the RCF upgrade.
Verify that the switch ports connected to the node storage ports and storage shelf ports are up.
show interface brief -
Verify that the expected node storage ports are still connected:
show cdp neighbors -
Verify that the expected storage shelf ports are still connected:
show lldp neighbors -
Verify that the node storage ports and storage shelf ports are in their correct VLANs using the following commands:
show vlan briefshow interface trunk
After you've upgraded your RCF, you can verify the SSH configuration.
